Oil - 0w30 or 5w30
viperbl
Oil - 0w30 or 5w30
Post by viperbl » Tue Jan 30, 2007 3:52 pm
Guys,
Just going to do an oil change, I notice that it currently has Castrol Edge 0w30 in at the moment, I tried to get 5w30 (but being the Isle of man, i'd be lucky to get what I wanted!) so they only had 0w30.
I bought that, but, should I hold off and get some 5w30 from the UK ????
Whats the main difference in using these two different oils? I do drive the car hard, if this needs to be taken into consideration ... oh, and its an RS4 engine ...
dummi
RE: Oil - 0w30 or 5w30
Post by dummi » Tue Jan 30, 2007 6:47 pm
sure oilman will be along soon but 0w40 or 0w50 is better, there are cam wear complaints with 0/5w30, the 0w40 would be better than 5w40 for lubrication of the turbos too. 0w50 would be good if you drive the car hard.
there are some good sticky threads on this topic at the top of the forums, check them out.
viperbl
Re: RE: Oil - 0w30 or 5w30
Post by viperbl » Tue Jan 30, 2007 7:04 pm
dummi wrote:sure oilman will be along soon but 0w40 or 0w50 is better, there are cam wear complaints with 0/5w30, the 0w40 would be better than 5w40 for lubrication of the turbos too. 0w50 would be good if you drive the car hard.
LOL, thanks dummi, how could have missed that sticky!!!
So, from reading everything, and your advice, I might swap the oil for 0w40 or 0w50 if I can find it ...
dace
RE: Re: RE: Oil - 0w30 or 5w30
Post by dace » Tue Jan 30, 2007 8:18 pm
5W40 is a good "all rounder" for our cars
Dave
dummi
Post by dummi » Wed Jan 31, 2007 8:49 am
np
JonnyX
Post by JonnyX » Wed Jan 31, 2007 11:13 am
I think a group IV or V 5w40 is probably best for our cars
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
viperbl
Post by viperbl » Wed Jan 31, 2007 11:51 am
I've gone my 10w60 as recommended by a good tuner.
Gonna need to be carefull on warm up, but suppost to be very good at high temps ..
RS4 B5 Saloon8) with 750+ bhp :D
>RS4<
Post by >RS4< » Wed Jan 31, 2007 3:40 pm
Why not 5W60 then?
An opinion is like an asshole,everybody has got one.
viperbl
Post by viperbl » Wed Jan 31, 2007 3:48 pm
>RS4< wrote:Why not 5W60 then?
I did not see that over here (limited options here!), and I was told that its harder to get old of 0w60 (and assume 5w60) because of the greater variation in cold and hot viscosoty.
MarkB
Post by MarkB » Wed Jan 31, 2007 4:02 pm
I've never seen a 0W60 or 5W60
If you are running high power and use if often then 10W60 is going to be good. as has been said though, take it easy when cold as the oil won't flow so well.
I use 5W40 because it's cheap as chips and seems to be the recommended grade. I also don't drive the car that hard so it never gets really hot. I'm also not running big power either
0W40 would be my next choice.
Mark
JonnyX
Post by JonnyX » Wed Jan 31, 2007 5:02 pm
0w60 is huge a viscosity range for a multigrade oil (IMHO).
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
