Rob1977
Post
by Rob1977 » Tue Oct 17, 2006 8:26 pm
Mikeyboy wrote:Slightly off subject but what determines the service interval types? Style of driving or personal preference?
If you do a lot of motorway miles then you will get the maximum benefit from longlife servicing,if you do a lot of town driving it will come on early,mine came on at 9k after 11/2 years in my last car so i changed it to normal intervals
Since the car usually comes on longlife anyway and the car has longlife oil in already from factory you may as well do the longlife until the first service and see what sort of mialage you get and make the decision to stay on it or not at the first service.
binder
Post
by binder » Thu Oct 19, 2006 7:56 am
I have had several Audis on longlife (A6 2.7T, S4 4.2 and RS4). On my RS4 at 5000 miles it was predicting service at 19000 miles but that was after several good long trips (Leeds - Goodwood etc.). Now after a spell involving commuting and town driving it is at 18000 miles. Over the three cars and about 9 years 100,000 miles + in total it has always ended up at around 17,500. I found when my dealers moved from the Longlife II spec (0W - 30) to the 5W-30 of Mobil 1 ESP, Castrol Longlife III or Edge 5W-30 that my oil consumption dropped noticeably and that the consumption settles down after a few thousand miles. You would expect a big engine to use more than a smaller one I think. RS4 magnificent!
binder
Post
by binder » Thu Oct 19, 2006 8:01 am
Re last message that should read 6 years not 9 before someone tells me longlife not around 9 years ago!
Mikeyboy
Post
by Mikeyboy » Wed Jan 03, 2007 2:42 pm
Bringing back the Oil thing from the dead. I had my car out over christmas. Day after boxing day 7.30 in the evening so dealer was closed. dipstick showed way below minimum using the prescribed method in the book. So bought the grade I remebered as being the right one 0W-40. oops. Have I done anything too bad i put in something like a liter or more?
Mikeyboy
Andyuk911
- 5th Gear
Post
by Andyuk911 » Wed Jan 03, 2007 3:35 pm
Mike,
As long as you have not over filled.
You should use Edge 5-30w, which is the consumer version of the bottle that came with the car.
If you did not get the poach, somebody nicked it !
Andy
RS4 Avant - Sold Aug 2009
Mikeyboy
Post
by Mikeyboy » Wed Jan 03, 2007 6:54 pm
I think a couple of things have gone walkies from the car. Did you get the underseat storage on yours Andy?
Andyuk911
- 5th Gear
Post
by Andyuk911 » Wed Jan 03, 2007 8:38 pm
I Don't think so .... I think that will be because of the bucket seats.
GlynRS2
Post
by GlynRS2 » Fri Jan 19, 2007 10:33 pm
What is the oil capacity on the RS4?
I plan to change the oil and filter at the end of the month as that will be 6 months and about 2.5K miles.
Reading the other thread about engine trouble I am going to opt out of the Longlife service plan.
Think I might try Fuchs Titan GT1 5w-30 VW504.00/507.00 in place of the Castrol, this gets good reviews stateside.
Glyn
Navarra Blue RS6 Vorsprung (C8)
Sepang Blue RS6 Performance (C7) - sold
Sepang Blue S5 sportback (B8.5)- sold
Monza Silver RS6 (C6) - sold
Sprint Blue RS4 (B7) - sold
Polar Silver RS2 (B4) - sold
RI_RS4
Post
by RI_RS4 » Fri Jan 19, 2007 11:38 pm
Just a tad shy of 10L if you change the oil and filter.
Daz
Post
by Daz » Tue Jan 30, 2007 10:00 pm
Does anyone know the part numbers for the filter and sump plug washer?
Is the filter easy to get to and remove?
I'm planning on giving mine an oil / filter change on Saturday.
Cheers,
Daz
Audi RS4 Cabriolet with added Milltek - Gone
GlynRS2
Post
by GlynRS2 » Wed Jan 31, 2007 8:03 am
Oil filter (incl. gasket) part no.: 079 198 405 B =£11.46 plus VAT (£13.47 incl. VAT)
Oil drain plug part no.: N 016 027 6 =£1.03 plus VAT (£1.21 incl.VAT)
Oil drain plug seal part no.: N 013 815 7 =£0.32 plus VAT (£0.38 incl VAT)
Don't know how easy as I have not tried yet.
According to the RS4 Spec Sheet from Audi the oil capacity incl. filter is 8 litres.
Glyn
Daz
Post
by Daz » Thu Feb 01, 2007 12:53 pm
Thanks for that, parts are in stock and I collect them on Saturday.
Now, does anyone know if the filter is going to be a pig to get to and get off?
Cheers,
Daz
MarkB
Post
by MarkB » Thu Feb 01, 2007 1:13 pm
If it's like on the V8 S4 it's from above and should be easy. You may need a special socket though if it's anything like the same setup BMW use (a big plastic nut that is easy to damage)
Mark
GlynRS2
Post
by GlynRS2 » Thu Feb 01, 2007 7:21 pm
Glyn
Daz
Post
by Daz » Thu Feb 01, 2007 8:04 pm
Thanks Glyn, that's just perfect. I should be able to get hold of a 32mm socket OK. Cheers.
Cheers,
Daz
Users browsing this forum: Google [Bot] and 280 guests
