Short shift fitting
Short shift fitting
Hi could anyone recommend a short shift kit and where to buy, also what are they like to fit and is there any websites which show fitting instructions. Also anyone who has one fitted is it a good mod and worth doing ??....
- shineydave
RE: Short shift fitting
mod your existing one, costs sod all and works just as well, i posted some instructions a while back in a short shifter thread on how to do it
Dave
Take a look here............ http://www.toyguy.o-f.com/
- shineydave
it's on this page
http://www.rs246.com/index.php?name=PNp ... r&start=45
Hobsons4 has just done his, says it's a tremendous improvement
Dave
- shineydave
that's true in that if you chop some length of the lever you can't easily stick it back on but you can move the bolt back to the original hole to put the throw back to where it was.h8cak wrote:If you mod your existing one you cant return it to original spec if required!!
it's probably all rhetoric though becuase i certainly wouldn't want to go back to the pudding stirrer
Dave
