Guys,
Do I need a tool to push back the callipers when I change these pads or is this only really for the rear ones???
Change Pads on RS6 Callipers
- shineydave
RE: Change Pads on RS6 Callipers
fronts just push back, rears only need the special tool to set the handbrake
Dave
Re: RE: Change Pads on RS6 Callipers
Cheers fellashineydave wrote:fronts just push back, rears only need the special tool to set the handbrake
- shineydave
RE: Re: RE: Change Pads on RS6 Callipers
np. it's a bit of a pain because there's so many pistons, as you push one back the others pop out, might be worth leaving the old pads in and levering them apart with a screwdriver or lever of some kind, don't forget to release the brake reservoir cap first and make sure you don't push the fluid level up so far it spils out
Dave
Re: RE: Re: RE: Change Pads on RS6 Callipers
Got you, good idea ... thanks.shineydave wrote:np. it's a bit of a pain because there's so many pistons, as you push one back the others pop out, might be worth leaving the old pads in and levering them apart with a screwdriver or lever of some kind, don't forget to release the brake reservoir cap first and make sure you don't push the fluid level up so far it spils out
Its those little tips that stop it becoming a 2 hours job i'll bet!
- shineydave
RE: Re: RE: Re: RE: Change Pads on RS6 Callipers
20 mins a side with a bit of luck, if the snow holds off
Dave
