On the Rollers
On the Rollers
I'm off to the Pistonheads Rolling Road day tomorrow at Surrey Rolling Road in Cobham...
I'm guessing that I'll get around the 420-430 BHP mark....anyone else want to hazard a guess ?
Spec is
K04s
Full Milltek include downpipes (single system with 200 cell cats)
RS4 ICs
730cc injectors
Bosch Motorsport fuel pump
MRC remap
Spec is
K04s
RS4 ICs
730cc injectors
MRC remap
scoobydood
- 1st Gear
RE: On the Rollers
It would have been really good if Zerok could have made it...... but he's a slacker
Facelift S4 with K04 + complete RS4 top end.
Eibach Pro Street S coilovers
RS4 front & rear brakes
Dyno 465/470
Dyno 465/470
RE: On the Rollers
What can I say....!
RE: On the Rollers
Surrey Rolling Road hold events for a few forums I think and are hopefully very experienced.
I believe the dyno is a DynoDynamics.
Make sure you get some figures at the wheels. I think the flywheel/crank or whatever you all the other figures will be a bit lower than you really expect (whether thats those posted above or not), but higher or lower it's the power at the wheels I think you should be sure to come away with.
KayGee got 312 BHP @ the wheels on the same dyno dynamics dyno I had my S4 on.
My uneducated eye looking at your spec above and KayGee's signature thinks KayGee's car just pips you on spec, but otherwise quite similar.
My money is on 302.4BHP @ the wheels
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
RE: On the Rollers
I'm going for 383 at the flywheel. If it's closest wins I want to be the lowest. See if you can get a copy of the graph to publish, that would be great. What was Leons(zeroK) supposed to be in the end. Last I read was anything from 430 to 500 ?
RE: On the Rollers
383 at the flywheel.....bit more than that I hope...I got 365 on the Surrey RR without the fuel system/MRC Remap or the ICs...
RE: On the Rollers
How much boost do you run Jeff ?
fletchie55
RE: On the Rollers
although all this power talk is fairly interesting, I think its the 0-60, 3-70 and 0-100 times (both in-gear and through the gears) that are more important, can you get these from a rolling road session?
I know the times are related to the power, but its difficult to judge in real terms what 50, 70, 100BHP etc will make, its pretty sure that the difference the extra power will make becomes less the more you start with. ie it requires a lot more power increase to feel the difference if you have 500BHP than if you have 100BHP to start with.
Going on from this, there must be an upper limit where if you have a certain BHP already, then you will need so much more to gain an appreciable difference that its just not worth it, in which case it is then time to start lightening the car up to feel the difference. is there a rough equation that relates KG to power? ie removing 10KG in weight give same effect as gaining 50BHP?
Jeff sorry if thats off topic! my guess is 420 crank BHP, 345 at the wheels. what is required to take your spec upto MRC 500? just lowered compression?
RE: On the Rollers
Manifolds and lower CR & the FMIC...as far as I know...probable a decat.
I don't actually know how much boost the car is running at the moment.
Re: RE: On the Rollers
Better intake pipes too + LWFW I think.jeffw wrote:Manifolds and lower CR & the FMIC...as far as I know...probable a decat.
Do you have a fats time? or a max maf reading?
I'm triying to get the maximum info before I 'guess'
RE: Re: RE: On the Rollers
That's cheating....pre ICs being fitted FATS was 4.0 (2 up) and MAF max was 320...
Ahhh of course....you need a LWFW (Lightweight Folding Wheelchair ?)
- ChipHazzard
I'll have a crack at 405
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
Based on latest FATS run estimated only at 400HP :'( - but I did have a slight miss-fire which got worse and worse. It is better now, not done a re-run. I will try rolling road it before and after the downpipes & exhaust is changed around month end. Lets hope I see or get very close to the magical 500.stimp wrote:I'm going for 383 at the flywheel. If it's closest wins I want to be the lowest. See if you can get a copy of the graph to publish, that would be great. What was Leons(zeroK) supposed to be in the end. Last I read was anything from 430 to 500 ?
Re: On the Rollers
Thats pretty much identical spec as my car and mine made 376bhp @ the flywheel on that very rolling road 6 months ago. However more importantly over 450 lb/ft of torque.
I will be interested to see what your makes especially if it makes 430bhp as 50bhp difference on virtually identical setups would need some explaining.
jeffw wrote:I'm off to the Pistonheads Rolling Road day tomorrow at Surrey Rolling Road in Cobham...
Spec is
K04s
RS4 ICs
730cc injectors
MRC remap
