B5 S4: "How to..."
B5 S4: "How to..."
This thread is an index to other threads containing guidance and information on how to perform specific tasks relating to S4 ownership, for example repair and maintenance tasks.
Adding posts to this thread
Members are welcome to add to this thread as long as the following rules are met:
1) This thread is not for discussion - if you want to ask about it please start a new post.
2) New issues should follow the same format - a clear title followed by a short concise summary, then links to the threads that provide the detail.
3) Existing issues can be edited, primarily to add more links. If you can't edit the thread, either add a post with the changes, and a moderator will tidy the thread later, or else start a new thread requesting the changes.
2001 Silver S4 Avant
RE: B5 S4: "How to..."
AUXILIARY WATER PUMP
Also known as the afterrun pump (see the "B5 S4: What every S4 owner should know" sticky).
The following thread is an excellent step-by-step guide on how to replace the pump. RS246.COM would like to thank SimonS4MTM for contributing this item.
http://www.rs246.com/index.php?name=PNp ... ic&t=53060
QuantumJohn
Front Door Height
How to adjust the front door height - in case they drop slightly:
http://www.rs246.com/index.php?name=PNp ... m&start=15
John
John
GEARBOX OIL INFORMATION
General thread regarding above.
http://www.rs246.com/index.php?name=PNp ... highlight=
S4B5 Avant
DIY REAR WHEEL BEARINGS
This is an excellent article on AW that I relied on to do mine.
http://www.audiworld.com/tech/wheel.html
S4B5 Avant
OIL CHANGE
A step-by-step guide by shineydave
http://www.rs246.com/index.php?name=PNp ... ic&t=58633
CHANGING SPARK PLUGS
Also covers changing the air filter
CHANGING POLLEN FILTER
ANTI-ROLL BAR TORQUE SETTINGS
http://www.rs246.com/index.php?name=PNp ... ic&t=58928
S4B5 Avant
QuantumJohn
RANGE OF USEFUL 'HOW TO's'
The thread below contains a link to a site that lists a whole range of useful 'how to' features. From Clearing the sunroof drains to performing an alignment of the suspension.
http://www.rs246.com/index.php?name=PNp ... ic&t=59166
John
John
- shineydave
- shineydave
QuantumJohn
DRIVESHAFT CV BOOT REPLACEMENT
Another thread that contains very useful how to information from Shiney Dave
http://www.rs246.com/index.php?name=PNp ... ghlight=cv
REMOVING HAZARD SWITCH/RELAY
Had a problem with my indicators flashing in an odd sequence, left okay - right a lot faster. So going to replace the above. Instructions for replacing this are on AW:
http://forums.audiworld.com/s4/msgs/1783172.phtml
S4B5 Avant
Users browsing this forum: No registered users and 22 guests
