B5 S4: Modifications
This thread is an index to other threads about modifying the S4.
Adding posts to this thread
Members are welcome to add to this thread as long as the following rules are met:
1) This thread is not for discussion - if you want to ask about it please start a new post.
2) New issues should follow the same format - a clear title followed by a short concise summary, then links to the threads that provide the detail.
3) Existing issues can be edited, primarily to add more links. If you can't edit the thread, either add a post with the changes, and a moderator will tidy the thread later, or else start a new thread requesting the changes.
2001 Silver S4 Avant
RE: B5 S4: Modifications
AFTERRUN PUMP
The S4 has a secondary waterpump which can be turned on by the ECU when the water temperature is very high. The pump operates in 'reverse direction' to the normal water flow so that air bubbles which form in the turbo water jackets are dissipated in the block. The following threads detail methods of modfying this so that the pump can provide turbo cooling after journeys:
QuantumJohn
After-run Pump Modification
This is the best thread I have found for the after run pump mod:
http://www.rs246.com/index.php?name=PNp ... t=run+pump
John
John
2000 MAINTENANCE SCHEDULE
As it says in my gallery
http://www.rs246.com/modules.php?op=mod ... at=0&pos=0
S4B5 Avant
HEADLIGHTS
General discussion and info on upgrading headlights
http://www.rs246.com/index.php?name=PNp ... ht=#150279
S4B5 Avant
S8 REAR BRAKE UPGRADE
Excellent tech article on AW:
http://forums.audiworld.com/s4/msgs/1716040.phtml
S4B5 Avant
APR BIPIPE
As the flexible throttle body boot (TBB) can split, causing an air-leak, one solution is the APR bipipe. This thread covers members' experiences of fitting it (APR's instructions are good and a link is included).
http://www.rs246.com/index.php?name=PNp ... ic&t=64321
Users browsing this forum: No registered users and 10 guests
