Snub Mount fitted to my RS4
Nige_RS4
Post by Nige_RS4 » Wed Jan 03, 2007 2:12 pm
After reading all the posts about the DTS, I was about to take the plunge and order one .... then my thermostat decided to play up, so during it's replacement I decided to fit a new snub mount (thanks Patrick aka Golich).
I can report a noticable improvement during gear changes, much less shunting when on/off the throttle (slow moving traffic) and the whole gear change feels much tighter / slicker.
If anyone is still undecided about fitting an DTS, then the snub mount is an excellent alternative, and much more cost effective, especially if you fit it yourself!
I'm not saying the snub mount is better than a DTS, becuase I have no personal experience with the DTS, but you can read an independant test here .... http://www.audiworld.com/tech/eng29.shtml
Anyways, during my quest for a snub mount at short notice, I've ended up with a spare one - yours for a mere £30!
Send me a pm if you're interested.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
ChipHazzard
RE: Snub Mount fitted to my RS4
Post by ChipHazzard » Wed Jan 03, 2007 2:22 pm
YHPM
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
MarkB
Post by MarkB » Wed Jan 03, 2007 3:11 pm
Glowing report and then... "I have one for sale"
Nice one :D
Mark
ZeroK66
Post by ZeroK66 » Wed Jan 03, 2007 4:58 pm
I have had one fitted to my car along with RS4 engine mounts and a DTS... and to be honest its a bit too much now. I get a lot of drivetrain shunt through the car when coming on and off throttle... its maybe a little too harsh... then again maybe as the mounts loosen up with time it will become very comfortable.
yorkie
Post by yorkie » Wed Jan 03, 2007 7:50 pm
Excuse my newbie ignorance but what is it and where does it go?
Where can you get one and how much are they?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Jan 07, 2007 6:38 pm
Or just adjust the snub mount bracket so it is hard down on the original rubber mount. You can get diffenent brackets so it is a tight fit into the poly snub mount.
http://www.MRCtuning.com
ZeroK66
Post by ZeroK66 » Sun Jan 07, 2007 8:46 pm
Explaint further Doug?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Jan 07, 2007 9:07 pm
snub mount is at the front of the engine bolted to the block - and it is locates in a round holed bracket that is bolted to the front panel. Now you can move that bracket down to push hard on the rubber/polymount and it stops the engine lifting under load. the rubber will always give a bit more play than a poly mount but you can still need to pull the bracket down hard to stop any knock. You can get diffentt brackets that make it all a tight fit. As long as th bracket is down hard I doubt it is worht it.
Golich
Post by Golich » Fri Feb 23, 2007 8:22 am
I've just had the snub mount fitted and it has transformed the car for me. I now no longer get that engine bang when changing down a gear to go for it. For years I've been forced to match the engine RPM with the speed and gear. It really made the car feel sloppy and its really bugged me. Now its all gone!
I have the DTS fitted too (and for some time) but I found it did very little.
Now my RS is running like it should have from day one. Which after a set of new tyres, front dampers and the RS6 brakes is making it very difficult to find fault to justify buying a B7 RS4. She's running so sweet I'm in love again and all this on a stock hp........
Nige_RS4
Post by Nige_RS4 » Fri Feb 23, 2007 10:29 am
Patrick, gut the pre-cats and go for an MRC custom map - you know you want to ;-)
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
S4TAN
Post by S4TAN » Sat Mar 10, 2007 2:17 pm
I had a poly snub mount fitted during my recent K04 conversion - i also have the DTS (a great piece of kit in my experience) - also adjusted the snub mount bracket so it's as hard down as i could possibly get it (this was prior to the poly snub mount being fitted) - all in all i get no play whatsoever: car feels really tight and together.
Deus ex machina
Ads4
Post by Ads4 » Wed Apr 11, 2007 8:55 am
Hmmm...another one to add to the list for when I'm next up at Doug's then Julian... :wink:
Adam.
MRC B5 S4 Avant.
ChipHazzard
Post by ChipHazzard » Wed Apr 11, 2007 9:24 am
That reminds me, I must get round to fitting mine It's been sat in the glove box for the last 4 months
FL Noggy S4 Avant
S4TAN
Post by S4TAN » Wed Apr 11, 2007 11:24 am
Yep - another one to the list Adam. PM me when you're up there next and i'll pop along and meet you there ...
Deus ex machina
A20LEE
Post by A20LEE » Mon Jan 26, 2009 10:58 am
How does the APR snub mount compare to the 034 one? Thinking about order the APR one as it will be easier to get hold of?
