Radio Code help
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
derdle
Radio Code help
Post by derdle » Thu Dec 21, 2006 10:40 am
Hi all,
My head unit has been giving crap radio reception recently and VAGCOm shows the follwoing fault code.
Can anyone explain and point me in the right direction to start searching for this elusive short?
00850 - Control Output Active; Radio Amplifier
29-00 - Short to Ground
Many thanks,
Paul
PetrolDave
RE: Radio Code help
Post by PetrolDave » Thu Dec 21, 2006 10:52 am
Sounds like the aerial amplifier in your car has gone faulty (the radio is reporting that it's trying to power the aerial amplifier but it is taking so much current it appears to be shorted). That would explain the crap radio reception.
Either the aerial lead from the radio to the amplifier has developed a short (not that likely) or the aerial amplifer has developed a fault (most likely). Often the aerial amplifiers crack and fail, this would be my number 1 suspect in your case.
derdle
RE: Radio Code help
Post by derdle » Thu Dec 21, 2006 10:55 am
Thnaks for the prompt reply...
And I suppose the aerial amp is that inconspicuous lump of plastic in the boot by the CD stacker....and no doubt there is no change from £ 100?
Paul
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 19 guests
