Gearbox oil information
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
QuantumJohn
Post by QuantumJohn » Mon Dec 18, 2006 10:58 am
Hi guys,
I have searched high and low for this but really need any anwser.
I understand that there should be approx 3 litres of oil in the gearbox. Can someone confirm this as I have read on the Audiworld site it should be nearer 4.2 litres with the gearbox and rear drive/transfer box?
There are 2 drain plugs, 1 on the fined casing of the actual gearbox and 1 on what I imagine is the transfer box at the back of the gearbox.
Does the one filler fill both these boxes i.e. are they all one? Does the 3 litres account for both of them?
Why have 2 drain plugs?
Thanks,
John
ChipHazzard
RE: Gearbox oil information
Post by ChipHazzard » Mon Dec 18, 2006 11:44 am
John
The gearbox holds just short of 3.5l I'll try and sort you the info from elsa later on when I get home, assuming her indoors doesnt want to take a quick spin down the test track to bluewater
Mike
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
QuantumJohn
Post by QuantumJohn » Mon Dec 18, 2006 11:53 am
Mike,
Thanks. I need this info pretty soon as what came out of my gearbox at the weekend explains an awful lot!
Thanks,
John
MarkB
Post by MarkB » Mon Dec 18, 2006 11:56 am
Do tell... isn't your engine and box super low miles?
Mark
ChipHazzard
Post by ChipHazzard » Mon Dec 18, 2006 11:57 am
IIRC the drain bolt on the box is on the underside and the filler is on the side by the driveshaft. I'm not sure if this does both the oil is 45/90, give me a bell later to remind me and i can pop up if you like and bring my laptop with me
FL Noggy S4 Avant
QuantumJohn
Post by QuantumJohn » Mon Dec 18, 2006 12:15 pm
Mark,
Yes it is/was.
I am afraid I can't go in to detail here yet in case it jepodises future matters.
John
MCB
Post by MCB » Mon Dec 18, 2006 12:15 pm
Spot on John
From memory (Failing) thought it was 2.5L, anyway I checked the level with a bit of bent wire 7mm down from fill hole, depending on who you speak to our boxes are/not sensitive to this. Also Motul 300 75w-90 was recommended so used that.
Just a thought, I made sure I could undo the fill plug before I drained the oil, sure you will do this.
S4B5 Avant
JonnyX
Post by JonnyX » Mon Dec 18, 2006 12:20 pm
Should be ~3 litres for the correct level (I am sure you can get more in!). The correct level
should be just below the fill hole. Pretty hard to gauge this on jackstands though as the
car has to be level. Asked Doug to check mine last time, when he pulled the plug about 1/2 litre
of oil poured out. To drain, you remove both the plugs on the underside. There is only one fill
hole which is on the NS of the tranmission casing, above the NS driveshaft.
Don't use a GL5 gear oil. I believe these have a high sulphur content which isn't great for brass synchros.
Remove the filler plug before removing the drain plugs. This helps with draining AND enables you to put
oil back in after draining. Apparently it's quite common to drain the transmission then not be able to
remove the filler plug to get oil back in!.
I think a fully synthetic 75w-90 is what is needed. Personally, I would get this from Audi.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
QuantumJohn
Post by QuantumJohn » Mon Dec 18, 2006 12:20 pm
MCB wrote: From memory (Failing) thought it was 2.5L, anyway I checked the level with a bit of bent wire 7mm down from fill hole, depending on who you speak to our boxes are/not sensitive to this. Also Motul 300 75w-90 was recommended so used that.
Thanks. I've also read that. Some people say 7mm below filler hole and the bently manual mentions up to the filler hole.
I didn't check the fill plug first but then not much point as the gearbox is going to have to come out anyway.
Thanks,
John
bneaves
Post by bneaves » Tue Dec 19, 2006 6:08 pm
I seem to remember its up to the filler hole for non S or RS boxes, ie no trans oil cooler. For box with cooler ive seen anywhere between 9mm and 7mm below bung level.
Also trying to get gear oil out of Audi is difficult as they rarely stock it in 1l containers, only 205l barrels
jacko788
Post by jacko788 » Thu Dec 21, 2006 12:12 am
guys stop being so pedantic please ur scaring owners away always fills gearboxes up to the filler hole till it just runs out,its splash fed so not that critical surely as long as u keep an eye on things.
jacko788
Post by jacko788 » Thu Dec 21, 2006 12:19 am
jonnyx says dont use a gl5 gear oil and MCB says motul 300 was recommended looked on the motul 300 can which my bro has put in his scooby box and it states this is a GL5 gear oil!!! another can of worms has been opened here i think lol
QuantumJohn
Post by QuantumJohn » Thu Dec 21, 2006 12:16 pm
jacko788 wrote:guys stop being so pedantic please ur scaring owners away always fills gearboxes up to the filler hole till it just runs out,its splash fed so not that critical surely as long as u keep an eye on things.
The gearboxes aren't just splash fed, they have a pump to get the oil up to the cooler and back.
John
MCB
Post by MCB » Thu Dec 21, 2006 12:35 pm
Also think the layshaft is submerged...
S4B5 Avant
BRETTCOLLINS
Post by BRETTCOLLINS » Thu Dec 21, 2006 12:38 pm
Hope you get it sorted soon john...
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Users browsing this forum: No registered users and 81 guests
