Does the DNA map run extra high boost at low revs?
Am i talking arse..?
Interesting; i'm guessing your boost gauge is tapped off your FPR hose? From my last vagcom log my peak actual boost (measured at the MAP sensor) is 2360mbar which equals about 1.36bar when you subtract atmospheric pressure - so same peak boost as you're running (20psi), but my boost gauge only ever registers about 17psi max - i guess this is because of the ~3psi pressure drop between the charged air pressure actually entering the throttle body to what comes out of the engine manifold and up to the boost gauge......it shows 20psi on the gauge..is that high?? 1.2 ta 1.3 bar??
