The new stalks look quite cheap, and some web comments suggest that the wiring is in place, and then just needs the CPU enabling ? There are some other comments about the traction control needing checking at the same time. Presumably you need the VAG laptop to switch off the airbag so you can remove the steering wheel and fit the stalk?
