What the hell is going on with my car ?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
C-24
Post by C-24 » Mon Dec 04, 2006 4:12 pm
Hi,
my s4 was fine yesterday, and today when I wanted to start it I couldn't move it.
Motor is running ok but I can shift gears but it does not couple and there is a slight noise. Clutch seems to work okay but there is no couple between gearbox and clutch system.
The gearbox is new (only 4k miles) and I don't know why is that happening.
Do you have any idea?
S4 avant imola yellow
Sportec remap 320hp / 500nm
Brembo GT-brakes
RS4 suspensions
h8cak
RE: What the hell is going on with my car ?
Post by h8cak » Mon Dec 04, 2006 4:52 pm
How do u mean? What it goes in to gear but no drive?
Wide Body S4
lobbers
Post by lobbers » Mon Dec 04, 2006 6:00 pm
sounds like a driveshaft has popped out
david7m
Post by david7m » Mon Dec 04, 2006 6:09 pm
Seems strange how it was working fine yesterday ?) Doubt the driveshaft would pop out whilst stationery/engine off ....
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
MCB
Post by MCB » Mon Dec 04, 2006 6:24 pm
Sounds like it could be a prob with the clutch, fluid / master cylinder????
S4B5 Avant
C-24
Post by C-24 » Mon Dec 04, 2006 6:30 pm
The engine is starting normally, but when I put it into reverse, first,second...fith, there's no reaction when unleashing the clutch.
Let's say I try to get it into reverse or first gear, I press the clutch put the gear on and then unleash the clutch : the car doesn't react, it's static! and you can hear a little noise like "rrrrrrrrrrrrr"
David, until today, the car was working perfectly, and I almost never push it hard. :(
Brembo GT-brakes
RS4 suspensions
s4woody
Post by s4woody » Mon Dec 04, 2006 9:52 pm
has sum1 deleted my post on this..im sure i posted before h8cak..
GARTH ROAD MOT CENTRE LTD
020 83353032
C-24
Post by C-24 » Mon Dec 04, 2006 10:00 pm
What did you say in that message? I don't think I saw your post.
Brembo GT-brakes
RS4 suspensions
s4woody
Post by s4woody » Mon Dec 04, 2006 10:02 pm
to check the gear linkage or prop..and if its going into gear with engine running i hope it aint a diff or driveshaft broken..mmmmm deja vue
020 83353032
C-24
Post by C-24 » Mon Dec 04, 2006 10:55 pm
Guys thanks a lot
I think it's front-left driveshaft that is broken (when we force driveshaft with a hand it moves easily)
We will see tomorrow.
Brembo GT-brakes
RS4 suspensions
fade2grey
Post by fade2grey » Tue Dec 05, 2006 8:40 am
yup, I had similar symptoms when I had problems with my rear drive shaft. Bolted back in & no problems since.
98/Missano/Bose/Carbon
QuantumJohn
Post by QuantumJohn » Tue Dec 05, 2006 12:05 pm
Does this mean that if one driveshaft goes drive to all 4 wheels is lost?
Does the S4 not have any LSD's?
Also, do you know how this happened as driveshfts just don't fall off/apart when stationary.
Thanks,
John
GrahamS4
Post by GrahamS4 » Tue Dec 05, 2006 12:13 pm
No LSDs. Back to the "what happens if one wheel is off the ground?" argument!
MarkB
Post by MarkB » Tue Dec 05, 2006 12:14 pm
Isn't there an LSD in the middle, just not front or rear?
Mark
Dr-Al
Post by Dr-Al » Tue Dec 05, 2006 2:11 pm
MarkB wrote:Isn't there an LSD in the middle, just not front or rear?
Isn't the middle one a Torsen?
Torsen diff FAQ
Wrecked on 9 Oct 2007: 1998 Cactus Green S4, 710N DVs, Boost gauge (in custom A-pillar/dash mounting pod), cruise control retro-fit, Parrot 3200 Colour Hands Free, RS246.com sticker
Users browsing this forum: Google Adsense [Bot] and 38 guests
