Connection between the S4 and the PC seems to be impossible!
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
C-24
Post by C-24 » Sat Dec 02, 2006 8:08 pm
Hi,
I just received an OBD II cable, and Vag-com software.
I tried several hours to connect my pc to the S4, and it's impossible!
I decided to try with an other laptop, same problem!
Vag-com says I have to select the COM port, so I select the Com3, it's okay and it says : interface status -5 MODEM
when I try to run some options like "engine" or "OBDII compatibility", it just doesn't work... it says : possible problems -> turn the ignition on, wrong interface or something like that...
I tried then many many other programs, same thing...:evil:
What do you think the problem is ?
Uwe@Ross-Tech
RE: Connection between the S4 and the PC seems to be impossi
Post by Uwe@Ross-Tech » Sun Dec 03, 2006 4:12 pm
If VAG-COM tells you you have a modem on COM 3, I would believe it. Go to Device Manager, pull up the properties sheet for your modem and see for yourself.
What kind of "OBD II" cable did you get? Is it 9-pin Serial or USB?
-Uwe-
C-24
Post by C-24 » Sun Dec 03, 2006 8:14 pm
I have got an R-232 (it's the serial cable) not the USB one.
I will try to resolve that, thanks.
But when you plug the 9-pin serial cable in the serial port, shouldn't the computer tell you something like "a new hardware has been connected" ? Because I don't get any message.
S4 avant imola yellow
Sportec remap 320hp / 500nm
Brembo GT-brakes
RS4 suspensions
MarkB
Post by MarkB » Sun Dec 03, 2006 8:46 pm
The serial port on the computer isn't Plug-n-play so won't pop up any messages.
Mark
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Sun Dec 03, 2006 11:44 pm
Correct.
Furthermore serial ports do not provide any power to the attached device so VAG-COM cannot tell if a serial interface is connected unless the other end is plugged into the car.
-Uwe-
oliew
Post by oliew » Tue Dec 05, 2006 12:09 am
is ur abs working, mine wouldnt connect while the abs ecu was broke.
S4 B5 - MRC
C-24
Post by C-24 » Sun Dec 10, 2006 11:27 pm
I think the abs is working...
I really don't know why I can't connect the notebook to the car...
I'm not sure how to choose the correct "COM" ... I'm really not a newbie when it comes to computers and everything, but now I feel like nothing's
working and I don't know what to do!
I am going to try with my third notebook (a real old one with windows 95, maybe that should do the trick?)
We'll see. :)
Brembo GT-brakes
RS4 suspensions
C-24
Post by C-24 » Wed Dec 20, 2006 11:10 pm
I tried the OBDII cable with 4 different computers, on both my father's A8 and my S4, and NOTHING's working!
What should I do ? Do I have to setup something in the device manager page? If so, how must I do it?
I would really appreciate if someone could tell me a step by step setup (and, yes, I read the rosstech site, I've done everything I could do on the computer)...
I can't resolve that problem from 3weeks or so and that's very annoying...
Thanks for help! :(
Brembo GT-brakes
RS4 suspensions
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Thu Dec 21, 2006 12:27 am
Ah, have you tried asking whomever you bought the lead from for help?
I can assure you that if you bought a lead from Ross-Tech or any of our authorized resellers that they would assist you with this, in real-time on the phone if necessary.
-Uwe-
MarkB
Re: RE: Connection between the S4 and the PC seems to be imp
Post by MarkB » Thu Dec 21, 2006 9:25 am
C-24 wrote:I tried the OBDII cable with 4 different computers,
Is the cable a Ross-tech cable or a generic OBDII cable?
Mark
C-24
RE: Re: RE: Connection between the S4 and the PC seems to be
Post by C-24 » Thu Dec 21, 2006 1:06 pm
It is a generic one. It's possible the cable doesn't work at all, in that case, it's a shame not to provide such a simple cable that works.
Brembo GT-brakes
RS4 suspensions
MarkB
Post by MarkB » Thu Dec 21, 2006 1:11 pm
I did wonder...
Which version of VAG-COM are you using? The newest you will be able to get to work is 409 I beleave...
Mark
C-24
Post by C-24 » Thu Dec 21, 2006 1:53 pm
I am using the 311n2 something like that (also tried the 3.0.3.1) because I don't have the USB cable, but the R-232.
Brembo GT-brakes
RS4 suspensions
MarkB
Post by MarkB » Thu Dec 21, 2006 2:20 pm
Looks like your lead is broke then
Mark
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 52 guests
