Cheap and cheerful mods?
- SimonS4MTM
- Top Gear
(1) Big triangular hole cut out front-side of air-box (+ optional multiple small drilled holes in bottom of air box) - £0Alps - No Eggs Please I'm British wrote: I thought I could try my hand at carrying out some cheap, not too techincal mods - and this way I'll hopefully learn my way around the car.. and soon onto to the path of doing some more daring stuff in the future.
(2) Clean out crap from air-box and clean air-filter - £0
(3) Replace all vacuum hoses (EM to FPR, EM to t-piece to DVs) - £5
(4) Replace Pollen filter - £9
(5) Remove spare wheel from boot - £0 (or £7.95 for a one-use "get you home" tyre inflator kit)
(6) N249 Delete - £1's worth of vacuum hose and a couple of clips
(7) Tighten and/or replace all reachable jubilee clips - £0/few
(9) Take off TBB and clean all the oil and crap out of the throttle body - £0
(10) De-mesh MAF - £0
(11) Give MAF sensor an IPA bath - £5
(12) Get engine warm, unplug ECU....wait 1 minute, re-connect ECU and do a 'proper' TBA using the "key method" - £0
(13) De-fog bumper grilles - £0
(14) De-flap the "other air inlet hole" - £0
(15) After-run mod - £10
£45 max i reckon - and you'll learn about your car. Plus it will go "better"....
(ok boys - let the slagging commence!)
Deus ex machina
- SimonS4MTM
- Top Gear
- dr_wimpkins
- dr_wimpkins
QuantumJohn
- ChipHazzard
Not helpful when the inside wall of the tyre bursts unfortunatly, has happened twice to me now, both rear tyres one while the car was parked up after I'd just done the tyre pressure's and the other at 15mph thankfully as I pulled away froma set of traffic lights(5) Remove spare wheel from boot - £0 (or £7.95 for a one-use "get you home" tyre inflator kit)
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
Good to see that i'm finally getting the recognition i truly deserve...Grey-manS4 wrote: Give me £50 and I'll give you the Emporer's tune.
Love to know what my tune is....care to enlighten me?
Deus ex machina
no no no...just cut a hole in ya bonnet and be the laughing stock of the whole forum.. now thats recognition..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Users browsing this forum: Majestic-12 [Bot] and 75 guests
