ABS cutting in at low speed
- SimonS4MTM
- Top Gear
Hi all
Some help please!
I can feel my abs cutting in at speeds below 30mph. Not all the time and very slightly.
Obviously this is an abs sensor or sensor ring problem, either dirt or corrosion.
The question is, how do I find out whcih corner of the car is causing the problem, without taking all four corners appart?
Some help please!
- SimonS4MTM
- Top Gear
RE: ABS cutting in at low speed
20 views and no responce!
Anyone got any ideas?
No ideas, but the same problem. I'm looking for answers too.
Already changed 1 ABS ring and I now have the problem on another wheel!
Wrecked on 9 Oct 2007: 1998 Cactus Green S4, 710N DVs, Boost gauge (in custom A-pillar/dash mounting pod), cruise control retro-fit, Parrot 3200 Colour Hands Free, RS246.com sticker
vag com mate should give you an intermittent fault?
will tell you which wheel sensor it is.
S4 B5 - MRC
- SimonS4MTM
- Top Gear
No faults shown on vagcom. If it is dirt on the sensor ring then no fault will be detected.
If you're popping over to Woody's on the 9th we can all take off a wheel each and check which sensor it is? Won't be as knackering that way.
01 RS4, Milltek, Dahlback Racing rears, RS6 fronts and a few bits to be added.
Also, as I hate driving, my toy to play with - a Honda CBR F Sport
- SimonS4MTM
- Top Gear
Great idea, all depends on the wifes plans though unfortunately.
SnapOn do an ABS tool that monitors signals from individual ABS sensors - my local garage has got one and they have picked up 3 damaged sensor rings in a couple of months. One guy with an S4 was planning on upgrading his rear brakes as he thought they were overheating (it was the ABS over-working them!!)The question is, how do I find out whcih corner of the car is causing the problem, without taking all four corners appart?
HTH
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
- SimonS4MTM
- Top Gear
hmmm, thanks Nige.
I wonder if you can monitor wheel speeds in vag-com? Anyone know?
Re: RE: ABS cutting in at low speed
You can, but the ABS module breaks the connection to VAG-COM as soon as it cuts in with the pulsing. This makes it pretty useless at diagnosing a faulty ring.SimonS4MTM wrote:hmmm, thanks Nige.
That said, I only have the freeware lead, so the full lead may work better.
- SimonS4MTM
- Top Gear
RE: Re: RE: ABS cutting in at low speed
DrAl
What address do you look at?
Is it not as simple as removing a wheel and the sensor to be cleaned is straight infront of you? ie nothing else needs to be removed?
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat
- SimonS4MTM
- Top Gear
You need to remove the upright assembly. The abs ring is on the end of the cv joint.
Not a particularly quick job!
I see
- SimonS4MTM
- Top Gear
Yes, pain in the
Users browsing this forum: Majestic-12 [Bot] and 40 guests
