17774 - cylinder 4 ignition circuit : short to ground
P1366 - 35-10- - - Intermittent
Have also had same but with cylinder 6
Any Ideas
Jimbo
Help with this code
RE: Help with this code
I had this, or similar on my car when i got it. cleared it an it never came back. I assumed it was one of the coil packs shorting to ground.
Mark
Check the connectors on the ignition amplifiers on top of the airbox. A disconnected coil pack can't throw a code because it's not connected straight to the ECU, the signal first goes through the power output stages(POS) or ignition amps.
HTH,
Mihnea
HTH,
Mihnea
Re: RE: Help with this code
Thats really helpfull. Never even thought about the fact that it would need to communicate back to the ecu. Easier to get to also...S2tuner wrote:Check the connectors on the ignition amplifiers on top of the airbox. A disconnected coil pack can't throw a code because it's not connected straight to the ECU, the signal first goes through the power output stages(POS) or ignition amps.
HTH,
Mihnea
Mark
HTH,
Mihnea
thanks for that
jimbo
RE: Re: RE: Help with this code
and if you need 1 to test against let me know..i have 2 spare from my RS4 airbox..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
