EGT's
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
h8cak
EGT's
Post by h8cak » Wed Nov 22, 2006 6:04 pm
Pluged my 98 S4 in to a fellow rs246's vag com and it kicked up both EGT's Does this mean they are fooked? Also how much, Where to get them and how dificult to fit?
Cheers guys
Wide Body S4
DavidT
RE: EGT
Post by DavidT » Wed Nov 22, 2006 6:37 pm
What were the fault (DTC) codes ?
s4woody
RE: EGT
Post by s4woody » Wed Nov 22, 2006 6:53 pm
and did you try clearing them then rechecking if they came back.. i got mine for about 75 quid i think..drivers 1 easy to fit passenger 1 a pain in the ass..
GARTH ROAD MOT CENTRE LTD
020 83353032
h8cak
RE: EGT
Post by h8cak » Wed Nov 22, 2006 8:43 pm
B0ll0cks i didnt write them down!! and i dont have vagcom :( Ill have to find somone to plug in for me again so i can get them. If they had gone would there be any symptoms? IE would i feel anything different when driving?
Wide Body S4
h8cak
RE: EGT
Post by h8cak » Wed Nov 22, 2006 8:46 pm
Oh and yes we did clear them and they came right back :shock:
Wide Body S4
craigs4
Post by craigs4 » Wed Nov 22, 2006 9:27 pm
when my egt sensors broke it went into limp mode and about 195 hp .6 bar boost. mrc changed them and got full power back.
h8cak
Post by h8cak » Wed Nov 22, 2006 9:46 pm
Ok so there is no power loss at the moment. But as they both came up on vag com does this mean that they are going to fail? what did mrc charge you?
Wide Body S4
neckarsulm
Post by neckarsulm » Wed Nov 22, 2006 10:10 pm
I've just paid Audi £160 for nearside EGT and that was with 15% off!
Labour isn't too bad if car is on a ramp, I can't see it being more than an hour but I am not a mechanician.
Check loom first for damage, it's weird silvery colour and mine was meandering through all the various pipes in bay (but alas was OK).
Can't wait to do it as its the only DTC logged!
h8cak
Post by h8cak » Wed Nov 22, 2006 10:31 pm
same as. Didnt have any other faults. Is it common for both to go?
Wide Body S4
jimbogrey
Post by jimbogrey » Thu Nov 23, 2006 12:47 am
When i purchased my car i thought it was standard, when it went for a service they logged both EGT's as knackered So i told them to change them and my god the performance difference was astounding. We examined the ECU and it was chipped.Itsubsequently transpired that the dealer i bought the car from had been running around in it for a couple of months with a knackered MAF and using 95 RON fuel, which may well have lead to lean running and an early demise of the EGT's
I now have VAG-Com so if you ever come up the A3/M3 to surrey give me a shout and I'll happily do some logging for you.
Jimbo
h8cak
Post by h8cak » Thu Nov 23, 2006 1:22 am
Good lad i may just take you up on that :D So i shouldnt run it on norm 95ron petrol then?
Wide Body S4
JonnyX
Post by JonnyX » Thu Nov 23, 2006 9:51 am
h8cak wrote:Good lad i may just take you up on that :D So i shouldnt run it on norm 95ron petrol then?
A standard S4 should only really be run on 98, a remapped one should
definitely only be on Super(97) or above.
vagparts now have EGT sensors in their online shop. 100 quid each exc. VAT if
I remember rightly.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
h8cak
Post by h8cak » Thu Nov 23, 2006 4:50 pm
so the slight loss of power i have been feeling may be the tesco's 95 ron petrol i filled up with :?
Wide Body S4
MarkB
Post by MarkB » Thu Nov 23, 2006 4:59 pm
h8cak wrote:so the slight loss of power i have been feeling may be the tesco's 95 ron petrol i filled up with :?
You Bad Man, Like feeding a cat fully skimmed rather than full fat!
If you're at the Windsor meet next week I should have my VAG-COM in the car. If I forget, peterb will have his no doubt.
Mark
s4woody
Post by s4woody » Thu Nov 23, 2006 6:19 pm
if your using tesco fuel just roll it about 2 inches forward and stick in the 99 ron..every little helps..
020 83353032
Users browsing this forum: No registered users and 98 guests
