Continuing problems
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
derdle
Continuing problems
Post by derdle » Wed Nov 15, 2006 4:52 pm
Hi all,
Colleague here at work has an A3 1.8T and teh EPC light has come, VAGCOM gives the following fault codes:
3 Faults Found:
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
The 17705 pressure drop has appeared before and various hoses have been changed, plus the DV changed and the throttle body cleaned.
Does anyone have any clues?
I've recommended that he take it to a specialist (probably MRC being the closest) but he doesn't fancy a day out of the office.
Many thanks!
Paul
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
Uwe@Ross-Tech
RE: Continuing problems
Post by Uwe@Ross-Tech » Thu Nov 16, 2006 12:35 am
This page might be helpful:
http://www.ross-tech.com/vag-com/cars/fuel-trim.html
I would certainly test the MAF in the manner described there.
-Uwe-
derdle
Post by derdle » Fri Nov 17, 2006 10:14 pm
Many thnaks for that. I've passed the info on to my colleague but I think he is too tight to have the car looked at properly. False economy in my mind, but hey ho...it takes all sorts.
Once again, thanks.
Paul
Return to “DTC / VCDS”
