SOB - DTC's are back
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
ronaldmacdonald
Post by ronaldmacdonald » Sun Nov 12, 2006 5:30 pm
I thought Id have a look at some codes after the display on the smphony radio seems to have gone garbled!
On the Engine front I got these babies:
4 Faults Found:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
17865 - Exhaust gas temperature sensor 2 open/short to B+
P1457 - 35-00 - -
17746 - Camshaft Pos.Sensor,Bank1 Open Circ./Short to B+
P1338 - 35-10 - - - Intermittent
17870 - Exhaust Gas Temp Regulation for Bank 2: Implausible Signal
P1462 - 35-10 - - - Intermittent
On the Radio front I got these beauties:
3 Faults Found:
00850 - Control Output Active: Radio Amplifier
29-10 - Short to Ground - Intermittent
00856 - Radio Antenna:
00854 - Output Radio Display Dash Panel Insert
49-10 - No signal - Intermittent
Anyone else pulled these codes or had a problem with the display on the radio unit going scrambled, oddly enough cd's dont seem to be playing from the changer now either - maybe its the start of the electrical meltdown! :shock:
flashyg
RE: SOB - DTC
Post by flashyg » Mon Nov 13, 2006 11:14 pm
egt sensor bank 2.
Positive deviation check for leaks
Cam shaft positioning wiring bank 1 check.
What happened after 2 days after clearing?
ronaldmacdonald
Re: RE: SOB - DTC
Post by ronaldmacdonald » Tue Nov 14, 2006 7:07 am
flashyg wrote:egt sensor bank 2.
I havent checked yet, Ive got a good 200 mile run today so Ill have a look when I get back.
Return to “DTC / VCDS”
