710n's Fitted, but getting a semi-dump Sound... this normal?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
ZeroK66
Post by ZeroK66 » Mon Nov 13, 2006 6:31 pm
Hi Guys,
Ignoring the fact that my engine is days away from being totally stripped to bits for many exciting thigns to be fitted... recently I have noticed on part throttle driving sometimes I hear a little bit of a whosh noise - VERY quiet, but still noticeable.
I drive everywhere with the windows down, so maybe that is the only reason I hear it. About 3k... part throttle squeeze, then let off and I get a tiny cchhh.
GrahamS4
RE: 710n
Post by GrahamS4 » Mon Nov 13, 2006 6:48 pm
I hope it's normal!
Mostly notice mine in 1st gear, but I quite often hear a tshhhh.
Russ,greys4
RE: 710n
Post by Russ,greys4 » Mon Nov 13, 2006 7:34 pm
yeah i think its normal, i changed mine 2 forge ones ages ago allways made a slight tissshhh! noise. got louder since i changed the exhaust!
The lowriders gone! But still loved. Long live the 911-C2!!!
Mcdubber1
Post by Mcdubber1 » Mon Nov 13, 2006 7:40 pm
I get the same sound since i drilled my airbox and i've still got the standard 710A's. Got 710N's to fit so hopefully it get's a wee bit louder. :lol:
S4 Avant
Mk1 Golf Gti
GrahamS4
Post by GrahamS4 » Mon Nov 13, 2006 7:46 pm
Can anyone explain why we hear a noise when they are recirculating DVs?
h8cak
Post by h8cak » Mon Nov 13, 2006 8:50 pm
It can be herd more when a cone filter is fitted. The S4 isnt too bad but my T Sport sounded like i had a dump valve fitted. It was very loud.
Wide Body S4
Dr-Al
Post by Dr-Al » Mon Nov 13, 2006 9:52 pm
GrahamS4 wrote:Can anyone explain why we hear a noise when they are recirculating DVs?
Here's my theory:
If there is a substantial charge pressure built up when they open, the air from the charge pipe and ICs gets 'recirculated' (ie dumped) into the hose between the Y-Pipe and the turbos.
The charge pipe and ICs contain a substantial volume of air that was under pressure. When this pressure is suddenly released, there is sufficient compressed air released into the open part of the system to allow it to briefly expand up into the Y-pipe and out of the intake.
This is one of the reasons why these cars use a hot film MAF and not a filament. The hot film can measure the direction as well as the amount of air passing over it, so it is not 'confused' by air 'going the wrong way'
Wrecked on 9 Oct 2007: 1998 Cactus Green S4, 710N DVs, Boost gauge (in custom A-pillar/dash mounting pod), cruise control retro-fit, Parrot 3200 Colour Hands Free, RS246.com sticker
h8cak
Post by h8cak » Mon Nov 13, 2006 11:31 pm
Cheers Doc................. now im even more confused :bash:
Wide Body S4
ZeroK66
Post by ZeroK66 » Tue Nov 14, 2006 12:11 pm
Cool all is well then :) - wonder what it will sound like with a set of K04's :P
Dr-Al
Post by Dr-Al » Tue Nov 14, 2006 12:43 pm
ZeroK66 wrote:Cool all is well then :) - wonder what it will sound like with a set of K04's :P
The magnitude of the decompression is proportional to both the volume of the compressed gas and the pressure difference.
IIRC, K04s have a 0.6 Bar wastegate actuator as opposed to the 0.4 Bar actuator on the K03, so this will increase the 'no load' charge pressure (ie the charge pressure with the N75 at 0% duty cycle), so I would expect the dump to be louder with the K04s.
Also, having a larger volume path after the turbos will increase the effect. So having RS4 ICs or a FMIC will also make it sound louder.
GrahamS4
Post by GrahamS4 » Tue Nov 14, 2006 12:44 pm
Totally different. I couldn't believe how like a totally different engine KayGee's car sounded. I actually prefer the sound of mine. Which is handy.
Dr-Al
Post by Dr-Al » Tue Nov 14, 2006 12:52 pm
GrahamS4 wrote:Totally different. I couldn't believe how like a totally different engine KayGee's car sounded. I actually prefer the sound of mine. Which is handy.
It would be chavtastic to have it as loud as possible!
I don't hear mine at all and that's the way I like it. There are plenty of spotty oiks driving around our town with their cars going Psst! every time they change gear. I don't feel any urge to be associated with them!
S4TAN
Post by S4TAN » Tue Nov 14, 2006 1:00 pm
Death to spotty oiks I say!!!!
Deus ex machina
david7m
Post by david7m » Tue Nov 14, 2006 1:31 pm
My 'dumping' seems to get louder when the air filter needs re-oiling. Will be doing this shortly.
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
ZeroK66
Post by ZeroK66 » Tue Nov 14, 2006 4:35 pm
I think the more turbo & gushing noise you hear when thrashing the car the better. BRING ON THE K04's...
