RS4 suspensions
RS4 suspensions
I got an S4 with 320hp, brembo GT braking system. It's a wonderful car,
but maybe it could be a little bit more "stable"
is it a good idea to buy RS4 suspensions ? I found some RS4 susps, for ~130£, but in "used condition".
What do you think about that ?
RE: RS4 suspensions
I've got the same fitted to mine for similar money and think it is really good. To clarify, car is daily hack and not used for any trackdays or other motorsport events. It reduced body roll and stiffened it up nicely but best of all, I can still go round country lanes without shaking the hell out of the passengers. The lower stance looks "Right" with 18" wheels and looks so much better at the front. Previously I had a Pug 205 16V on Konis that was great, a Vr6 that was on H&r which was harsh but O.K and they finally leaked so got changed for Konis(again superb). Was going to give the H&R's another try on the S4 but group buy went smelly so bought S/H RS4 set-up and am quite happy with those now.
Also have same 320ish Hp as yourself and RS4 brakes. For me the car now is just about perfect for it's intended use.
RE: RS4 suspensions
Thank you for replying,
Are the RS4 suspensions lower than the S4's ? Becauce I have 17" (avus) wheels with 225/45/17 tires.
You said the 18" wheels fit "right", so with 17" wheels, rims would be too small ?
C-24
C-24
S4 avant imola yellow
Sportec remap 320hp / 500nm
Brembo GT-brakes
RS4 suspensions
Brembo GT-brakes
RS4 suspensions
- mikeyquattro
- Top Gear
RE: RS4 suspensions
I have rs4 suspension with avus rims. Only lowers car about 15-20mm. Looks ok.
Have you an avant or saloon?
Tomorrow is another day
- ChipHazzard
RE: RS4 suspensions
I've got a full set of RS4 springs & Dampers waiting to be fitted to my S4 Avant Is it worth getting RS4 ARB's as well ???
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
17" wheels would look fine. As Mikey said it is somethinkg like a 20mm drop. I found the front appeared to drop more than the rear that made each end look even. Mine stock was nose up with a much larger gap between the front wheels and arches. Also have RS4 anti roll bars but did not fit them as they measured the same thickness and appear to be identical so no point. Mines an Avant.
- mikeyquattro
- Top Gear
Stimp
Yes they are the same size but are stiffer as they are made from a different grade of steel. They have different partnumbers ect. Worth fittingstimp wrote:17" wheels would look fine. As Mikey said it is somethinkg like a 20mm drop. I found the front appeared to drop more than the rear that made each end look even. Mine stock was nose up with a much larger gap between the front wheels and arches. Also have RS4 anti roll bars but did not fit them as they measured the same thickness and appear to be identical so no point. Mines an Avant.
Wide Body S4
Re: Stimp
RS4 antiroll bars are the same part number as S4 anti roll bars. THERE IS NO DIFFERENCE BETWEEN THEM!h8cak wrote:Yes they are the same size but are stiffer as they are made from a different grade of steel. They have different partnumbers ect. Worth fittingstimp wrote:17" wheels would look fine. As Mikey said it is somethinkg like a 20mm drop. I found the front appeared to drop more than the rear that made each end look even. Mine stock was nose up with a much larger gap between the front wheels and arches. Also have RS4 anti roll bars but did not fit them as they measured the same thickness and appear to be identical so no point. Mines an Avant.
gmbh did a thicker rear bar for the RS4 but it was an option, not standard
Mark
RE: Re: Stimp
It's what ETKA tells me!
To upset you even more the A4 Sport versions have the same bar also...
Mark
I've just purchased RS4 Quattro GMBH shocks and springs ( no rear ARB ) but not got it fitted yet. The thing that bugs me most about a standard S4 is the ride height especially the front sitting higher than the rear so i'm hoping this kit will level it out and also make it sit a bit lower and more aggressive aswell. Hopefully a set of H&R ARB's will be added sometime in the future to control the roll.
Mines an Avant running standard 17" Avus!
S4 Avant
Mk1 Golf Gti
Mk1 Golf Gti
S4 Avant
Mk1 Golf Gti
Mk1 Golf Gti
Users browsing this forum: No registered users and 43 guests
