Xenon dipping for Europe is possible, switch is in the unit!
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
UKS4APR1
Post by UKS4APR1 » Mon Oct 25, 2004 10:44 pm
There is a small wire/lever behind the cover of the headlight which needs simply flipping over to swap your dip for continental driving.
Bit tricky getting to it [lack of room]
Switch from circled position to arrowed position in pic. or vice versa.
flipbail XENON DIP.jpg (111.82 KiB) Viewed 1507 times
Mik
Xenon
Post by Mik » Mon Oct 25, 2004 11:10 pm
Very useful tip. Beats having to put annoying little stickers on my head lamps when going abroad :roll:
Mik
2014 Suzuka RS6
UKS4APR1
Post by UKS4APR1 » Tue Oct 26, 2004 10:48 pm
The other point is that those "annoying little stickers" DO NOT in fact work on the xenons as the light is not deflected by the headlight glass in the same way as conventional headlights.
Mik
Post by Mik » Tue Oct 26, 2004 11:41 pm
Never knew that and I once got told off by French Police for not using the stickers on on the xenons.
2014 Suzuka RS6
JohnW
Post by JohnW » Wed Oct 27, 2004 10:44 am
They make special stickers to use on projector style xenons.
We tried looking for these switched at the ferry port last week on DaveP's RS4 and could not find them.
Maybe its a case of only being able to get at them with the HID connector removed. :roll:
I will investigate further this weekend and see what I can discover incase anyone is interested (maybe only the RS4 owners...).
Too many toys, not enough time
docurley
Post by docurley » Wed Oct 27, 2004 11:14 am
This is great as I just purchased the RS4 lights on the left-hand drive car being broken up and assumed I would have to buy new shells.
Thanks for the post
JohnW
Post by JohnW » Wed Oct 27, 2004 11:25 am
It is possible you still might need to :roll:
If they are the same you have a result, but it would be worth checking.
From experiences with xenons on Porsches the Uk and mainland europe lights are different.
With a uk porker light the beam raises to the left to illuminate roadsigns and the kerb.
When you switch the switch on these it cuts the beam pattern so it is flat.
With a european porker light the beam raises to the right, and is cut to flat when switched.
The simple answer is to compare the parts numbers and lights prior to fitting them.
The next solution would be to just swap over the HID beam unit which should be screwed into the light moulding.
docurley
Post by docurley » Wed Oct 27, 2004 1:03 pm
Could someone post up there UK lights part number so I can compare and thanks.
Dippy
Post by Dippy » Wed Oct 27, 2004 1:48 pm
In my experience you need to remove the single unit headlights to change the switch. It is about half hour per headlight if you are being careful (make sure there is NO chance of the high voltage Xenons being turned on when you work on them). You also need a torx screwdriver and one of the screws is recessed to it has to be long (and it could also do with being magnetic so that you don't lose it!).
I might also point out that "Yes Mr. Gendarme my headlights have been internally changed to suit right-hand driving" does not always work and if he can see the stickers he's unlikely to cause any problem.
So I just use the stickers 'cos it's a lot less hassle.
2001 Silver S4 Avant
Morpheous
Post by Morpheous » Thu Nov 04, 2004 12:48 am
Bloody French Police!!!!!!!!!!!!!! Dont take a Road Angel to France. Even if its turned off they will confiscate it.
Friend of mine was also fined £500 on the spot fine!!
All recent Audi cars have this facility.
Was able to switch mine on the tunnel crossing.
GrahamS4
Post by GrahamS4 » Sun Nov 12, 2006 1:47 pm
Possibilty I am going to Germany soon for a few days - was thinking of driving. This alone is putting me off. What a faff.
DrB
Post by DrB » Sun Nov 12, 2006 9:17 pm
I eventually managed to change mine when I went to Germany in the Summer: http://www.rs246.com/index.php?name=PNp ... ht=#117190
When you flip the switch they do not flip over the lights but block out the top left corner.
RS 6+
2001-2006 S4
2006-2012 RS6
2012-2016 ML350 CDI
2016-2018 RS6 PE
2018 - Tesla MS100D
DrB
Post by DrB » Sun Nov 12, 2006 9:18 pm
Sorry I forgot to say, once you have done this once it will only take 2 mins per light to do.
RS 6+
2001-2006 S4
2006-2012 RS6
2012-2016 ML350 CDI
2016-2018 RS6 PE
2018 - Tesla MS100D
GrahamS4
Post by GrahamS4 » Sun Nov 12, 2006 9:34 pm
Thanks.
Scotty
Post by Scotty » Sun Nov 12, 2006 11:48 pm
I had something similar on my TT but when I pulled my head lights out on my 2003 S4 I couldn't see anything like it.
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
Return to “Audi S and RS Ownership”
