RS6 Calipers -> RS6 or B7 RS4 Disks/Pads?
viperbl
Post by viperbl » Mon Nov 06, 2006 9:50 pm
Guys, Guys, Thanks, Mountains of information there to digest ...
Here is a link to those Phaeton ducts, I am liking this idea!
http://www.rs246.com/index.php?name=PNp ... rake+ducts
SteveH
Post by SteveH » Mon Nov 06, 2006 10:03 pm
Here's a couple of comparison pictures... Although I must credit the sources, the RS6 disc is from rs6.com and the RS4 disc is one of clives photos from a previous post:
Present:...
Past:
MarkB
Post by MarkB » Mon Nov 06, 2006 11:16 pm
If only the new RS4 disc was handed...
Mark
whisky180
Post by whisky180 » Mon Nov 06, 2006 11:24 pm
MarkB wrote:If only the new RS4 disc was handed...
not quite sure about the merits of handedness all i know is the rs4/6 combo stops my car without any fuss wobble and judder and i am running approx 470bhp
noggy blue s4, mildly modded
MarkB
Post by MarkB » Mon Nov 06, 2006 11:28 pm
viperbl wrote:Guys, Guys, Thanks, Mountains of information there to digest ...
I've just had a thought.... the Phaeton ducts may not fit using the RS6 disc. The disc is more inset (reason for requiring the caliper bracket)
The ducts work with std B5 RS4 disc's but I don't know if there would be clearance for use with RS6 disc's. I would assume them to be OK with B7 RS4 discs as the offset is the same as the B5.
Mark
buzzard
Post by buzzard » Tue Nov 07, 2006 12:14 pm
is there any major weight difference in all these set ups (unsprung weight and all that)?
S4 B5 long gone
S4 B8 Stage 2
DavidT
Post by DavidT » Tue Nov 07, 2006 12:41 pm
I'm moving this to Tuning & Modifications as there is plenty of general interest in this thread.
David
boxerdogted
Post by boxerdogted » Tue Nov 07, 2006 1:21 pm
The only problem that i have been told about with regards to using RS6 discs is that you have to remove the splashgaurd to fit them, this can lead to cooked cv boots if you dont allow the discs to cool after spirited driving and track days.
2001 RS4 Misano Red
MarkB
Post by MarkB » Tue Nov 07, 2006 2:07 pm
boxerdogted wrote:The only problem that i have been told about with regards to using RS6 discs is that you have to remove the splashgaurd to fit them, this can lead to cooked cv boots if you dont allow the discs to cool after spirited driving and track days.
Ah, so as I thought, Phaeton ducts won't work with RS6 disc's, you need a caliper bracket because of the offset change, they are heavier because of the method of 'floating' the disc, but they are handed.
I'm now thinking B7 disc's may be the easier/better option unless you really need the extra durability of the RS6 disc
Mark
jeffw
Post by jeffw » Tue Nov 07, 2006 5:18 pm
Fully floating discs don't work in road cars very well as they tend to jam-up quickly.....fine for race cars where they are maintenaned reguarly but a more difficult proposition on road cars.
viperbl
Post by viperbl » Tue Nov 07, 2006 5:21 pm
Well guys,
I have gone for the RS6 Calipers, Pads and RS4 B7 Disks. I also order the Phaeton ducts to help with the old cooling...
Thanks for ur advice, I will let u know how I get on!, oh, and there will be some RS4 B5 Calipers for sale if anyone is interested?
RS4 B5 Saloon8) with 750+ bhp :D
SimonS4MTM
Post by SimonS4MTM » Tue Nov 07, 2006 6:12 pm
What did that cost you if you mind me asking?
CliveH
Post by CliveH » Tue Nov 07, 2006 6:18 pm
viperbl wrote:Well guys,
Good choice :thumbs: exactly what I did - sorry I didn't have time to contribute.
BTW, a great write-up on your car in this month's Audi Driver :kissmyrings:
Clive
Doug_S2
Trader (Expired)
Post by Doug_S2 » Tue Nov 07, 2006 6:31 pm
The pheaton ducts do fit the rs6 discs. I have fitted the ducts to rs4 setups, rs6 setups and a small porker brake setup.
The b7 rs4 setups do not fit every wheel and if you need to space the wheel out to fit, it can start to rub on the arches. But then they are cheaper becauSe you do not need custom brackets - but then the discs are more expensive than rs6+ - it is all a compromise! Some 18" BBS wheels do not fit becasue the inside diamter is too small - so they need custom, custom brackets!
I advise evreyone to fit one of these as you will never doubt the brakes again!
http://www.MRCtuning.com
SteveH
Post by SteveH » Tue Nov 07, 2006 9:47 pm
Doug, would the phaeton duct benefit/fit my rs6?
Also, the discs you fitted at the weekend are superb!!! I did get some strange looks when bedding them in on the M40 afterwards, had to time it so there was minimal people around as I did'nt want to knaff anyone off. They were nicely "blued" in by the time I got to the NEC.
Present:...
Past:
Users browsing this forum: No registered users and 26 guests
