Powersteering pump whining
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
ZeroK66
Post by ZeroK66 » Tue Oct 17, 2006 3:30 pm
Hi Guys,
My car has been in twice now to Audi and I have complained about the "common" whine of the compressor when manovering when stationary. Now I increased the pressure of my tyres the other day and it is better, but it does still make a noise when cold.
Given the car is under warranty (Bursts into fits of laughter as if this were a joke) surely a noisy pump should be replaced regardless of how quiet it is/when it makes a noise? If it makes a noise it should be replaced?
Cheers,
Leon
MarkB
RE: Powersteering pump whining
Post by MarkB » Tue Oct 17, 2006 3:33 pm
Maybe it is your wider tyres that have caused the problem so it's not covered...
Mark
ChipHazzard
Post by ChipHazzard » Tue Oct 17, 2006 3:51 pm
My power steering pump whine's on full lock and has done since i got it, I was led to believe that it's a common characteristic
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
oliew
Post by oliew » Tue Oct 17, 2006 3:54 pm
when i do a 3 point turn sometimes when the wheel is locked over fully it feels like the steering isnt power assisted for that first bit of the turn, needing a bit of pressure to like free it up.
S4 B5 - MRC
ZeroK66
Post by ZeroK66 » Tue Oct 17, 2006 4:21 pm
Maybe its the ARB's, maybe its the coilovers, maybe its the wind! I know they will probably try get away with it. When it next goes in I will stick the standard alloys on.
My car does the freeze like yours Ollie - generally when I park it up on full lock then re-start it later on. its horrible.
Noise on full lock I think is "acceptable" but not while manovering... which mine does.
SimonS4MTM
Post by SimonS4MTM » Tue Oct 17, 2006 4:26 pm
You should not hold it on full lock as this puts excessive strain/pressure on the pump.
I heard somewhere that the wine was a pressure relief valve.
S4TAN
Post by S4TAN » Tue Oct 17, 2006 4:46 pm
I get this too - common "feature" (sic)
Deus ex machina
boxerdogted
Post by boxerdogted » Tue Oct 17, 2006 5:30 pm
Make shure that the oil level is correct ,if low you can get air in the sytem which makes it noisey.
Also make shure it has the correct grade of oil in it, std atf type oil is not suitable in our cars and can cause pump and rack failure.
2001 RS4 Misano Red
JonnyX
Post by JonnyX » Tue Oct 17, 2006 6:55 pm
Get yourself a wife. The PS pump 'whining' will be the least of your worries... ;-)
<ducks>
I'll get me coat...
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
confusionhunter
Post by confusionhunter » Tue Oct 17, 2006 8:23 pm
every car Ive owned with PS whined on full lock.... mind you thats only been 4...
Mark.
saf
Post by saf » Tue Oct 17, 2006 8:30 pm
Happens on all S4's ive seen at full lock.
Not at other times though.
Maybe an idea to drain and change the fluid.
ZeroK66
Post by ZeroK66 » Tue Oct 17, 2006 10:06 pm
JUST TO CLARIFY
***I DONT HAVE A PROBLEM WITH FULL LOCK WHINE***
Its just when manovering IE: Parking spaces etc that I got it when the pressure was low on the tyres/when cold.
shineydave
Post by shineydave » Wed Oct 18, 2006 12:06 am
could be the same thing, when you go on to full lock the pressure relief will open as the rack is physically restrained at the end of the rack movement and the oil has to go somewhere or a hose will go. in your case the size of the tyres and low pressure may be causing the same effect, i.e, the pump is producing full pressure but the system can't turn the wheels immediately because of the increased contact patch due to the width and reduced pressure, therefore the oil has to go somewhere so it goes down the relief
ZeroK66
Post by ZeroK66 » Wed Oct 18, 2006 9:29 am
Okay, well to answer that. The car made a noise with my standard alloys on at the correct pressure when cold... I should think this means something is not right with the pump?
First time it went in to Audi was with the std alloys on... of course they didnt get the car cold, so dismissed it, but did the other work I needed doing.
shineydave
Post by shineydave » Wed Oct 18, 2006 8:33 pm
sounds like the spring on the pressure relief has gone weak then.
