resetting the service interval?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
K9ng
Post by K9ng » Mon Oct 16, 2006 7:08 pm
Tried searching but can't find how to reset the service interval?
TIA
S2tuner
Trader (Expired)
RE: resetting the service interval?
Post by S2tuner » Mon Oct 16, 2006 8:01 pm
If you have a vag-com, it's dead easy.
Connect to address 17, instrument cluster. Click on adaptation (10), select channel 02 and change whatever value is in there to 0. click "save" and confirm then that's it.
HTH,
Mihnea
K9ng
Post by K9ng » Mon Oct 16, 2006 8:20 pm
I don't have Vag-com :roll: Is there any other way?
S2tuner
Trader (Expired)
Post by S2tuner » Mon Oct 16, 2006 8:29 pm
uhhhhh, there probably is another way but I don't know it.... I'm sure you can find someone with vag-com not too far away from you though...
K9ng
Post by K9ng » Mon Oct 16, 2006 8:31 pm
Ok cheers, think I know someone.
S4TAN
Post by S4TAN » Tue Oct 17, 2006 9:51 am
You can do it from the dash board - i think it goes like this: ignition off, press and hold the second button (the one on the right) protruding from your gauge display, then turn the ignition key to the penultimate position (i.e. everything on but the engine) then the service indicator message will display in the DIS, wait till this disappears then release button, then turn key all the way off. When you next start the car the service indicator should be totally re-set.....
Deus ex machina
oliew
Post by oliew » Tue Oct 17, 2006 9:52 am
k9ng,
-Turn off the ignition
-Press and hold the button on the left side of the display while turning the ignition on
-Service OIL will be displayed
-Pull out the button on the right side of the display until the service prompt is gone
-The display should read ---
Ol
S4 B5 - MRC
S4TAN
Post by S4TAN » Tue Oct 17, 2006 9:59 am
.........ok - i knew it was something like that (writing it from memory) :wink:
Deus ex machina
oliew
Post by oliew » Tue Oct 17, 2006 10:12 am
:P
maybe both ways work?? :) hehe
S4 B5 - MRC
S4TAN
Post by S4TAN » Tue Oct 17, 2006 10:16 am
Possibly Ol! 8) It's in the manual anyway, surprisingly enough it's under "resetting the service interval" in the index! Who'd've thought it eh? :twisted:
Deus ex machina
K9ng
Post by K9ng » Tue Oct 17, 2006 3:58 pm
Thanks Chaps I managed to find it in the manual this morning :oops:
h8cak
Post by h8cak » Wed Oct 18, 2006 5:51 pm
Right, Just had to reset my 98 S4. It goes like this...... Ignition off , Press Right button, Turn ignition on, Pull out the left botton, this will reset the OIL service, To reset the inspection you need to press the right one again untill INSP apears, Then pull the left button again, Turn ignition off, Turn on again and hey presto DONE
Wide Body S4
Golfather
Post by Golfather » Wed Oct 18, 2006 8:53 pm
Yo k9ng, if you ever need VAGCOM, give me a shout :)
K9ng
Post by K9ng » Thu Oct 19, 2006 8:06 am
Cheers Golfather :thumbs: Will have to meet up soon :bigwave:
Return to “DTC / VCDS”
