Time again for a new set of brakes for the beast... The age old question is do I buy "standard" discs or cross-drilled discs.
If I used my car on the track it would be a no-brainer, cross-drilled all the way... But the fact is that I don't track my car, I have always used the standard solid/vented discs and have never had an issue with brake performance, those 8-pot Brembo's are brilliant and solid discs cope fine for my driving style, rarely do they get super hot.
Although its a brash statement, for my driving I don't reckon that there will be any performance difference between XD and normal discs, so aside from the aesthetics of XD looking cooler
One camp says that the XD brakes last longer because the gases produced when pad meets disc can be dispersed quicker and run at a lower temperature, so they last longer as they are less likely to warp, they wear at a slower rate.
The other argument is that the XD discs are prone to cracking, and unless you clean the discs regularly, the vents fill with muck & brake dust so there is no point in them being drilled in the first place, therefore the solid discs last longer.
HHHEEELLLLPPPP!!!!??????
