Thank you.
TV in motion
- bbigman2000
TV in motion
Somone please tell me how I overide the 2mph cut off
Thank you.
Thank you.
03 Plate RS6 Mugello Saloon
RE: TV in motion
If its the same Nav plus as in the RS4, then all you need to do is remove the unit and disconnect the blue/white GALA wire from the back. It may be worth extending the ends of the wires into the glovebox so that you can reconnect/disconnect them easily if you want to. Apparently the GALA wire has something to do with improving the accuracy of the navigation.
HTH.
Paul.
HTH.
Paul.
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
- bbigman2000
RE: TV in motion
What others have done is to incorporate a switch in this circuit; as the RS6 has most options fitted as standard you don't get many "blank" switch plates on the dash, but assuming you don't have the electric rear blind, you can buy the switch from audi and wire it into the GALA wire connecting the speedo to the Nav unit.
Present:...
Past:
Past:
- bbigman2000
RE: TV in motion
I do have the rear blind mate !!!
So are you guys saying if I diconnect the GALA wire, im going to have no link up between the speedo and the NAV ?
RE: TV in motion
Well, I think signals are taken from the abs sensors, which are then used to more accurately determine your position, however, I have run mine disconnected for some time now, with no noticeable difference in the Nav performance/location.
It's probably worth extending the wires (as I have done with simple spade connectors in the glovebox) or as SteveH says, with switch hidden away somewhere, just in case you do encounter some issues with it disconnected.
You need special removal keys, but you can get these from Halfords. There are four slots for the keys, but you can get away with buying a pair with a bit of fiddling!
Failing that, you could always ask your local stealer to remove it for you.......
- bbigman2000
- shineydave
or you can split a set of feeler gauges and use the individual feelers, one in each slot
Dave
Users browsing this forum: No registered users and 60 guests
