Anyone know if RS6 rear discs fit S4?
Other than the obvious need for a different caliper carrier so that the caliper sits further back, is the offset of the disc different too?
Anyone done it??
Anyone done it??
Clive
RE: Anyone know if RS6 rear discs fit S4?
Clive .... looks like you hit a brick wall there dude .... no anoracs can put there bit in on this .... wish they would - coz be interesting dude
What about Tourag rear's........ was eyeballing some on motorway other day..... look fat and quite capable of doing its job well....?
come on you anoracs ... get out the closet and answer the questions ???????
please .....
- shineydave
I've been out of the closet for years, trying ferociously to get back in
Dave
Methinks Dave (aka Rolskii) is being a little bit mischievous here........keep up the good work Davey boy!
Deus ex machina
Me .....? never mate ..... just cynicism builds with age .....
so to pre-empt your answer to that ...... bolox
Now can we have some answers on the RS6 rear brake set up, or even if tourags will be suffice as well ..... please ....
I did see an new RS4 breaking on ebay .... it was under rs4 catagory .....
spares are there .....
quick ....
Have ordered new anorac for you Dave, hope i got your size right......
Deus ex machina
I hope its embelished with rs246 or audi ...?
and not some dodgy stealers or rescued comms company dude .....
no feral branding on my back mate
to keep in post devilman!!!! I cant find late build part numbers for quoted above .... get your anorac out lucifer ...
Re: RE: Anyone know if RS6 rear discs fit S4?
Hi David!rolskii wrote:I cant find late build part numbers for quoted above .... get your anorac out lucifer ...
Are you referring to part nos. for RS6 rears...?
Clive
It's got a big cock emblem on the back, just the way you like it!
Back on post: Don't know part numbers either - are you looking for rear brake setup for your car? Personally I'd have thought you don't need rear brakes, or front ones for that matter, seeing as how it hasn't moved from MRCs car park for the last 2 months!!
Deus ex machina
RE: Re: RE: Anyone know if RS6 rear discs fit S4?
Hi Clive
Yes also Tourag no's .. not sure if PCD is same on them ..
if anything else is common on their r/brakes too..?
S4TAN wrote: Personally I'd have thought you don't need rear brakes, or front ones for that matter, seeing as how it hasn't moved from MRCs car park for the last 2 months!!
Dunno about Toerag part nos., but likely to be the same as Cayenne...?
Clive
S4TAN wrote:It's got a big cock emblem on the back, just the way you like it!![]()
mate
No I have a set of b5 rs4 rears on there way to me....
no worries at all for my car taking a well earned rest in MRC's .... all sorted with bigger turbs than you
as for the anorac ... I dont want your hand me downs either - thx
I will go see my mate at windrush in the week, he's a tech and may put some light on the subject for me..... let ya'll know.....
ta'ra
I checked on etka... late touareg, vented disc ~ my06 are not compatible, calipers and offset I cant check on that but pcd's are different.
also dont have tech. details on etka, it carries the same part numbers throughout, but changing the model number of chassis/build, have to actually get the parts and try to see if rs4/rs6 will swap, maybe caliper carriers of the rs6 will swap out and give you the extra 23mm+ extension needed due to that size increase on the discs. . .
Might be a bit off topic, but do you really need to fit uprated rear brakes? The front stoppers on your car are 'slightly' uprated
Why would you need to go for anything bigger than standard RS brakes on the rear?
Users browsing this forum: Google [Bot] and 61 guests
