You have PM.
Ben
Any new physical Avants knocking about?
Ben, one is for exit time delay on front lights which can be set in the DIS menu, the other is for daytime running lights, if you look at the front lights, the inner lights are not high beam, they are 21 watt bulb which acts as your 'Volvo' lightsbjacks wrote:Thanks chaps![]()
Shame there's no visual representation of the sensors.
Another quicky, what's that GDL knob thing for by the light switch? Not had time to read the 330 page user manual yet
Splendid sir. I like the exit thing, lights up the garage nicely.simple1 wrote:Ben, one is for exit time delay on front lights which can be set in the DIS menu, the other is for daytime running lights, if you look at the front lights, the inner lights are not high beam, they are 21 watt bulb which acts as your 'Volvo' lightsbjacks wrote:Thanks chaps![]()
- PetrolDave
And if you REALLY want the full Volvo look you can even use VAG-COM to change the coding so that your rear lights come on as well!simple1 wrote:the other is for daytime running lights, if you look at the front lights, the inner lights are not high beam, they are 21 watt bulb which acts as your 'Volvo' lights
