problem at start
problem at start
Hi guys,
has anybody any idea or experience with this:
Sometimes the engine doesn't want to start. After some attempts it does his work, and does it well in the next two-three days. Then does it again.
Welcome any idea. Thanks, P.P.
RE: problem at start
Hi Peter,
Some one on the B5 forum has had the same thing recently. DIdnt see a solution. Could be expansion in the fuel tank. Can try undo the lid on the tank to release the pressure.
Another thing would be to check your tempreture sensor. The car has one in the waterline to tell if the engine is warm or cold & then fuels the car accordingly.
Do you have the problem always hot or always cold? if it is consistently at the same temp then it is likely to be the sensor.
Dear ZeroK66!
Thanks a lot your quick answer, i'm going to check these two possibilities.
Peter
Peter
Re: RE: problem at start
Hi,
I have the same problem and I am trying to find a solution.
"Could be expansion in the fuel tank. Can try undo the lid on the tank to release the pressure."
What do you mean with expansion in fuel tank? Could you please explain to me?
Do you mean the "green" temp sensor, or does the car have more than one temp sensors?
Thanks,
Gregory
Thanks,
Gregory
RE: Re: RE: problem at start
I am not sure where the temp sensor is. Someone on here should be able to answer that.
By expansion in the fuel tank I mean fuel in the tank evaporating and this then pressurises the tank. I know this can affect some cars, not sure if it does the S4... but certainly worth a try.
Having a very similar issue on my RS4, only when the engine is cold, and about once every two weeks....very random! However, the car is due to have a cam chain tensioner replacement as on cold start one of the chains rattles which can effect the timing of the engine. I'll find out when the tensioner is replaced if the problem is related.
Users browsing this forum: No registered users and 184 guests
