Hi,
ive searched the forums for this and only found 1 problem the same but no conclusion was found in the posts.
my nearside xenon is lower than the other one sometimes , if i run the up/down adjusting through VAG they go to the same height, then it auto adjusts back down after i come out of vag, also no error codes are reported in the xenons module.
If i adjust with screwdriver then surely if the nearside goes back ok (which it does do) it will be aimed right up high, so is my sensor playing up on the roll bar? what can i do to fix this?
thanks in advance
Oli
Nearside Xenon lower than right
S4 B5 - MRC
RE: Nearside Xenon lower than right
You only have one sensor in the front and one in the rear so I would look first at the servo on the offending light
Mark
right, so if there is not a sensor for each side of the car it must be something just for that light, where is the servo for the light?
S4 B5 - MRC
