Burning Smell?
Burning Smell?
on take off when i take it up to 4000rpm been happening the last two days, any ideas?
2001 Audi RS4 Avus
2003 Range Rover Vogue V8 Java Black
RE: Burning Smell?
Oil from the rocker gasket hitting the manifolds....................
Re: RE: Burning Smell?
2nd. Have the same problem myself right now. When you stop the car,simple1 wrote:Oil from the rocker gasket hitting the manifolds....................
lift the bonnet up. You may get white smoke coming up through then engine
bay.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
- quattrosteph
Smmmmmmmmmmmell!!!!!!!
Sound like like rocker cover seals to me or the tiny ones on the back of the engine ( for cam tensionner...). It did on mine , the leak was of course behindthe head and it was dripping on the turbo and down pipe. So of course very smelly inside the car as well.
The best thing is to replace the all lot in the same time: rocker cover seals+ seals for cam tensionners.
I just remind you that oil on hot turbo can.........catch fire
So get it fix as quick as possible!!!
Porsche 996 Turbo S Atlas Grey.
RS4 B7 Avant Sprint Blue. Sold.
RS4 B5 Avus Silver with MRC magic . Sold (Best car ever )
S4 B6 Avant Nogaro blue. Sold
A6 Avant Silver . 2.5 TDI .Sold
Hi Shahel,
Agree with everything that's been said here. If you're lucky, it's a cam-cover gasket, if you're not, like I wasn't, it's a leaking rear drivers side cam-tensioner oil seal gasket. Doug at MRC did mine about a month ago. Whilst it was apart he did all the belts, water-pump, oil servive, new plugs, etc. No change out of £1,200. He also found a few leaks on the turbo system so, fo me, it was good value.
Tell-tail sign of leaking cam cover or rear cam-tensioner is oil smoke coming out of the drivers side front wheel arch as it drips onto the cat.
Hope this helps, and good luck!
Jarv
Jarv
Mike
Q7
Q7
Users browsing this forum: No registered users and 83 guests
