S4 - B5 to B6/7..?
tartan_rob
S4 - B5 to B6/7..?
Guys - just thinking about moving and been offered a nice noggy blue saloon with good mileage and good spec for a good price. How do they compare?
I am currently running circa 450bhp and I know it'll be a drop in performance but when the std B6/7 is compared to a B5 stage1 say...?
I'd like to hear from those that have moved and what are the pros/cons and likes/dislikes..?
Thanks,
Rob
Thanks,
Rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Hi Rob
Mentioned a little of this in another post (S3 or S4), but basically my thoughts are, the B5 is better & more fun when you're not belting it (around town, say) - more responsive to throttle movements at lower revs (felt more torque-y), but get above 5k and the B6 is superior. Standard brakes much better too. Steering also an improvement on the B6 (though still a little dull). And then, of course, there's the V8 soundtrack
Build quality - B6 has been very reliable, but I'm not convinced on the interior materials, eg carpets in the B5 I thought were superb (certainly better quality than the B6). Didn't have Recaros in the B5, but the seats in the B6 are supremely comfortable (I do long motoway runs every week, up to 5 hours at a time, have never been in discomfort, AND I suffer from an occasional bad back).
tartan_rob
I looked into things and I was debating S4 or OLD S3...
I decided on the B6 S4... as for the same age/year of S3 I could get an S4 for about £4k more... and for me to upgrade the S3 to similar power was going to cost £5-7k with no way of getting that money back.
I hunted for aaaaages for an S4... I had the filter on Autotrader mileage, year etc etc... that is how I came across my low mileage B5. I took cause of its mileage & price. Nothing could touch it.
I am soooo glad I got the B5. The B6 is heavy, very thirsty on juice & no upgrade path whatsoever. Sad, but true. It does look and sound good... probably rides better too.
Either buy an Evo or a B5 RS4... or an RS6. I dont think you will be happy otherwise.
My 2c
My 2c
tartan_rob
If you upgraded your B5 up to 450bhp I guess you like the "dragster thrust" of the turbos. So pretty sure you will not like B6/B7 (S4 or even RS4).
The power distribution is different: B5 you have a low rev instant power, B6 is much more like you own 2 cars: normal saloon below 3500rpm and the beast after.
B5 is highly upgradable (a lot of work to have it ok).
B6 stock already has good brakes, direction, decent suspension (still can be improved) and most of all, like almost all NA engine nowadays, no tuner cares investing time to really improve its performances (you can find a mild improvement on low rev torque and limiter removal but don't expect much more whatever people may boast )
It is up to you to try. But honestly I don't expect to see any B5 S4 big fan to go for a B6/B7 S4
tartan_rob
tartan_rob
I have MugelloR's old B6 S4 and I need to be honest, initially I thought the car was a lot slower and still when cruising in 6th I find it slow, but if you use the gears it is a quick car - just not as fast as the turbo beast.
The power delivery is sooooooo different and they can't be tuned for sensible money but the re-learning how to get the best from them is fun and I'm really sorry, but the exhaust note pulls the same smiles as the on-boost acceleration used too. When passing a bus stop etc I can blip the throttle and the whole bus stop turns round to look, that never happened with the B5...
It is different fun, I am not under the bonnet every 10 mins checking I have no air leaks etc. So from that point of view NA motoring is less stressful, I have no cool down period although I do allow the car to cool before switching her off...I am confident the RS4 engine or the RS6 engine could be tailored to fit...but then you are bakc upto the costs and then it becomes cheaper to buy the original car you wanted in the first place.
Just my 2pence worth.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Nice one TR!!!Tartan_Rob wrote:I have MugelloR's old B6 S4 and I need to be honest, initially I thought the car was a lot slower and still when cruising in 6th I find it slow, but if you use the gears it is a quick car - just not as fast as the turbo beast.
- BlingBling
On paper and more importantly on the road the standard B6 S4 is quicker than a standard B5 S4 so I'd hazard a guess, modded.JohnRet. wrote:Thanks for that
When you say 'it's not as fast as the turbo beast' do you mean standard or modded?
Because on paper, it's faster am I right?
I have noticed over on the B7 RS4 page those with B5 RS4's stating how slower the new incarnation is in comparison tend to have AMD Stage III or the like in their signature
