dvd player for oem tv
rs4steve
Post by rs4steve » Sun Jan 19, 2003 12:49 am
phil/bushy is it possible to link an aftermarket dvd player to factory fitted tv if so what would you recomend ?
cheers steve
PhilT
RS246.com
Re: dvd player for oem tv
Post by PhilT » Sun Jan 19, 2003 12:55 am
I think there is an input somewhere. I think it's in the boot, so I would consider getting portable DVD and putting it in the center armrest in the back. Slide out with it's own screen, and feed OEM TV. You can get power from the rear 12v outlet.
Sounds like a damn good idea to me.... [img]images/graemlins/smile.gif[/img]
rs4steve
Post by rs4steve » Sun Jan 19, 2003 12:57 am
thanx
Bushy
Post by Bushy » Sun Jan 19, 2003 12:44 pm
yep in rear of sat nav in boot
uses std av connectors
Can't beat a bit of boost!
PhilT
RS246.com
Post by PhilT » Sun Jan 19, 2003 12:52 pm
So what do you think to my idea Steve? Sounds cool.
Bushy
Post by Bushy » Sun Jan 19, 2003 12:56 pm
soz
only if u have sat nav plus is wot i meant
Carl
Post by Carl » Sun Jan 19, 2003 9:24 pm
Hi! i´m using a panasonic dvd, fitted in the rear left and connected to the tv module via rgb. theres is an infrared eye in the front for the remote. works perfect.
RS4 rulez
rs4steve
Post by rs4steve » Mon Jan 20, 2003 1:33 am
does playstation work on same setup?
Bushy
Post by Bushy » Mon Jan 20, 2003 10:07 am
yep
well any input you like really
even a laptop! although the screen would be smaller than the laptop itself!!!
PhilT
RS246.com
Post by PhilT » Mon Jan 20, 2003 10:10 am
I use an input for my video camera. Some people have a reversing camera. As Bushy says, just about anything.
Riz_RS4
Post by Riz_RS4 » Sat Feb 01, 2003 11:00 pm
So in theory if i had a S3 with Sat Nav+ that the Unit in the boot has inputs for audio/video on them too?
What connections does it have? rgb? svhs? phono`s?
And how do you select the input from the front?
Cheers for the info [img]images/graemlins/smile.gif[/img]
Image I`m just a hardcore petrol head :)
Bushy
Post by Bushy » Sun Feb 02, 2003 8:49 am
Riz
connection is RGB
I guess you must have an aux connection, unless when it senses a signal it accepts that
ANyone who has done this?
Riz_RS4
Post by Riz_RS4 » Sun Feb 02, 2003 10:34 am
I dont actually have a TV in my S3 [img]images/graemlins/frown.gif[/img]
But obviously going to look into this when i get my next one [img]images/graemlins/smile.gif[/img] RGB is good indeed [img]images/graemlins/smile.gif[/img] could even hook my xbox up to it [img]images/graemlins/smile.gif[/img] wow!
I could well run some extended RGB cables all the way from the back to the front under the car mats and into the glove box [img]images/graemlins/smile.gif[/img]
boff
Post by boff » Thu Feb 13, 2003 2:12 am
Hi Chaps
I've just stuck a DVD player in the boot and plugged into the SatNAV Plus box in the boot (or TV module combined). The Input Connectors are as follows:
1* Stereo RCA Pair (Audio Red+Black)
1* RCA Composite Video in (Yellow)
1* SVideo in
You need to use either the Composite Video or SVideo. You can't use these inputs together.
Hope this helps - btw nice forum
Best Regards
Zero Drama
Bushy
Post by Bushy » Thu Feb 13, 2003 6:57 am
hi boff welcome here mate
hope all is well
Return to “Electrical”
Users browsing this forum: No registered users and 62 guests
