water dropping from front of the car near the left wheel
as stated in the title its near the front of the left front wheel just behind the bumper is this normal? should i get it checked out also the water not all the time but has done it twice over the last few days
2001 Audi RS4 Avus
2003 Range Rover Vogue V8 Java Black
RE: water dropping from front of the car near the left wheel
Have you had any rain recently?
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat
Hows the coolant level - if its going down surpise surprise youve got a leak from somewhere in the system. Most likely offender is afterrun pump located in V below intake manifold or could be simply be a clip thats come undone from one of the hoses.
Could be one of the headlight washers, or the washer reservoir pump leaking? This is common on S4's, not so sure about the RS4 though?
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
As per S4int... my pump leaks...
Yes i agree with Simple washer bottle hose happened to me a few months ago same water drip i'll look back on my bills for the water bottle fix
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Fair enough but it was on my mind as paying for petrol recently all the cars including our new landy seemed to have sprung leaks for a moment before the explaination dawned.simple1 wrote:behind the front n/s wheel towards the centre of the car.............. so its not thatThe washer bottle is a known problem and sits about where the leak is coming from.........
Washer pump is quite cheap to replace (about £30 from memory) but it is a bit of a pain to change. You need to remove the n/s front wheel and arch liner then you can see the washer tank. The pump is on the inside so you need to remove the tank completely to change the pump.
