rs4 d/pipes to s4 miltek fit...?
MarkB
Re: RE: Re: RE: Re: RE: rs4 d/pipes to s4 miltek fit...?
Post by MarkB » Thu Aug 31, 2006 9:04 am
S2tuner wrote:Even bolts Mark, honestly, you can buy plugs for lambda bungs for just a few quid and at least you have the bungs in case the car ever needs a wideband to be installed, even temporarily, as for getting mapped for instance.
Just a thought.
Mihnea
Point taken. When and if I do mine I'll get some or get some made for me. I'll keep the welder away...
How do you connect the wideband lambda normaly when there is no tapping?
Mark
S2tuner
Trader (Expired)
RE: Re: RE: Re: RE: Re: RE: rs4 d/pipes to s4 miltek fit...?
Post by S2tuner » Thu Aug 31, 2006 9:15 am
Mark, when a car has no extra lambda bung, we just weld one in and then when mapping is done we just put a normal plug in so a sensor can be used again at a later time. ;)
tanoga
Post by tanoga » Thu Aug 31, 2006 9:57 am
Incase it is of any use the thread in the sensor hole in the RS4 downpipes is M18 x 1.5mm pitch.
MarkB
Re: RE: Re: RE: Re: RE: Re: RE: rs4 d/pipes to s4 miltek fit
Post by MarkB » Thu Aug 31, 2006 10:32 am
S2tuner wrote:Mark, when a car has no extra lambda bung, we just weld one in and then when mapping is done we just put a normal plug in so a sensor can be used again at a later time. ;)
So you do this with every car you custom map?
Mark
MarkB
tanoga wrote:Incase it is of any use the thread in the sensor hole in the RS4 downpipes is M18 x 1.5mm pitch.
Great. Thanks
Mark
