Audi A6 2.5TDI very bad white smoke from rear?
abc5k
Post by abc5k » Wed Aug 30, 2006 12:42 pm
Hi
Can anyone help? Pure white smoke coming out of A6 2.5 TDI rear Pipes year 99, have checked head its ok have checked all cylinder compression and that ok to it is burning a lot of oil , can anyone help me in this situation?
thanks Ash
grizz
RE: Audi A6 2.5TDI very bad white smoke from rear?
Post by grizz » Wed Aug 30, 2006 2:14 pm
ash , it could be the the turbo!
Unit 20
0151 3366888
philipwalker
Post by philipwalker » Wed Aug 30, 2006 2:59 pm
As Grizz suggests it could be the turbo the problem, is more noticable on idle?
Pull the hose from the airbox to the turbo off and check the movement in the turbo, should only be a slight side movment.
Other known problems with this engine are often caused by a blocked crankcase breather. It is located in the V of the engine to the rear of the fuel pump. The crank case pressure builds causing oil to be forced out from the turbo seals. This is obvious when removing the oil cap. There is a test that the dealers perform using a pressure tester in the dipstick hole.
abc5k
white smoke
Post by abc5k » Wed Aug 30, 2006 8:46 pm
thanks Phillip , you are correct thats whats wrong with it . thank you very much !
Return to “General Car Chat”
Users browsing this forum: No registered users and 88 guests
