Which coolant?
Which coolant?
As the title suggest which coolant should I be using in the RS2?
Worryingly it seems to have used a little in 3-4000 K's of driving. Not loads but some for sure.
Off on holiday in it soon so if you know don't be shy and tell me, I don't trust my local Audi garage after they sold me some 15W 50 oil for it (which I believe is wrong now)
Re: Which coolant?
Nothing wrong re oil. Lots of opinion around but its within spec and some prefer 'thicker' oil. Just change it every 6k/6 months with a good fully synthetic.LHD wrote:As the title suggest which coolant should I be using in the RS2?
Re coolant pink G12 unless you have it full of blue coolant. DO NOT MIX . If you are using the older spec blue get it replaced with the newer pink coolant. If you top blue with pink you get solids forming in the coolant. Just ask my previous main dealer how painful that was for him to sort !!
If losing coolant then have a look round the engine bay for evidence i.e dried coolant. Run until hot and check all pipes. Feel under all of them as well as looking. Check radiator condition. Get it pressure tested.
However if you spot nothing and a garage spots nothing and it passes a pressure test do not give up checking all the pipes. As they age they tend to split and this can be difficult to spot as they leak under pressure with a hot engine. Coolant runs under the pipe to somewhere else and may evaporate it its adjacent to a very hot area making it a b*gger to spot.
After run pump a favourite source of leaks that passes any pressure test. Located to R of block behind radiator as you look in with 3 pipes IIRC attached. Have a careful look for coolant under it BUT if you are tighting banjo clips be careful with these as you can split the pump plastic hose joints !!!
RS2 'an estate car named Desire'
Re: Which coolant?
Thanks for the advice regarding the coolant. Unfortunately my local audi garage gave me the pink stuff and said it was perfectly fine to mix it! (mines the blue stuff). Even more unfortunate I didn't see this thread until I'd done it although there is no evidence of any deposits yet, maybe as I only used a tiny bit I'll be lucky.alastairg wrote:Nothing wrong re oil. Lots of opinion around but its within spec and some prefer 'thicker' oil. Just change it every 6k/6 months with a good fully synthetic.LHD wrote:As the title suggest which coolant should I be using in the RS2?
Starting to seriously mistrust my local garage. They fitted a new undertray and left some of the screws out as well!
Re: Which coolant?
I really would find a trusted specialist and get the coolant drained and replaced with pink only. Coolant has a finite life and pink is newer and better than blue. Which by definition must be several years old or non audi origin.LHD wrote:Thanks for the advice regarding the coolant. Unfortunately my local audi garage gave me the pink stuff and said it was perfectly fine to mix it! (mines the blue stuff). Even more unfortunate I didn't see this thread until I'd done it although there is no evidence of any deposits yet, maybe as I only used a tiny bit I'll be lucky.alastairg wrote:Nothing wrong re oil. Lots of opinion around but its within spec and some prefer 'thicker' oil. Just change it every 6k/6 months with a good fully synthetic.LHD wrote:As the title suggest which coolant should I be using in the RS2?
As I would advise with new ownership change all fluids and filters including the fuel filter and ignore any main stealer who says its not needed !!
