Rear hub removal
Rear hub removal
Just spoken to the mechanic who is struggling to undo the central drive shaft nut. Any tips on type of tool to use.
tartan_rob
RE: Rear hub removal
Tip for the future: loosen that bolt before the brakes are dismantled so you can `lock`the hub by applying the brake.
- shineydave
any half decent mechanic would know to undo it on the ground before he took the wheels off.
Dave
Or use a 3/4 in air gun !! Works every time..
Unit 20
0151 3366888
0151 3366888
Only if you have a 14mm Hex socket
