VAGCOM Error Codes
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Jarv
VAGCOM Error Codes
Post by Jarv » Wed Aug 16, 2006 10:36 pm
Hi guys,
I ran my mates VAGCOM over my car this evening and it came up with the errors below. I am by no means an expert on VAGCOM and would be grateful if someone is if they could let me know what it means? I do currently have annoying glitches with the drivers side front footwell light and front courtest light and an intermittant problem with the TV, but whether that relates to the below errors, I don't know:
The errors are as follows:
Address 17 -------------------------------------------------------
Controller: 8D0 920 981
Component: B5-KOMBIINSTR. VDO D13
Coding: 00464
Shop #: WSC 00618
WUAZZZ8DZ1N902350 AUZ7Z0Y1627704
1 Fault Found:
01304 - Radio
49-10 - No Communications - Intermittent
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 63251
3 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Jarv
Mike
Q7
Return to “DTC / VCDS”
