what laptop for vagcom purely?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
dummi
Post by dummi » Sun Aug 13, 2006 9:38 am
i bought a USB-HEX from the uk vagcom distributor last year, i tried it a couple of times with my old laptop - dell P3 500mhz on win 98 se - i could find a port that would show up as active but i could not access any of the modules.. now i'm looking for a laptop when i get my car running hopefully in a few weeks i can use purely for vagcom, i'd like some advice on what to look for specification, OS ,, with my past experience of it not working i am not confident i know what laptop to look for , i have a chance to look for something simple and specific for this now
thanks
maxxximus
RE: what laptop for vagcom purely?
Post by maxxximus » Sun Aug 13, 2006 10:00 am
Exclusively for VagCom - how many times do you use it. Unless your in the motor trade id have thought it would be better just to upgrade your present laptop and use this for Vag com and all your other stuff.
I use my Dell 9300 P4 for vag com (Win XP) - works fine with key USB. Perhaps you could buy a PDA running windows mobile.
Nige_RS4
Post by Nige_RS4 » Sun Aug 13, 2006 10:04 am
I'm running a 166Mhz toshiba with vag-com (serial interface) !
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
maxxximus
Post by maxxximus » Sun Aug 13, 2006 10:26 am
Just checked and Vagcom is not compatible with Windows mobile/Palm oS at moment so looks like your stuck with a laptop.
Generally if youve got an old PC running Windows 98 youd be better using a COM/serial interface but if youve got a newer PC(pentium4) then USB shouldnt be a problem.
Might work better running under Xp but no guarantee.
dummi
Post by dummi » Sun Aug 13, 2006 10:45 am
Niges4 i was thinking of something like that, not anything hi tech really. not looking to upgrade this laptop for a while it does its job still and i usually have a desktop available.
Maxxximus i wouldn't be keen on the little screen of a PDA anyway.
so the thoughts are something older and cheap like a 166hz with serial interface, maybe if i tell you how my usage will be
when the car is together again i'll want to make sure its running enough to get through MOT , so adjusting idle, TBA, checking sensors are functioning.
after i have run the engine in i'll be off to MRC to have it mapped, then i'll be using vagcom for FATS and generally monitoring the cars behaviour , would the old serial version do all that for me? are there any functions the USB can use better than the serial? i'm guessing its mainly about speed and sampling thats different ....
thanks
Paulm
Post by Paulm » Sun Aug 13, 2006 11:23 am
I only have an old Compaq Armada 333Mhz 128ram and it works fine. I use USB. I used it on 98 then put on XP both worked fine.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
CliveH
Post by CliveH » Sun Aug 13, 2006 11:57 am
Dummi,
The "old serial" version will do just fine, which is Ross-Tech's preferred method of communicating.
Apparently, data rates are limited by the car not the serial port, and the USB version is only supplied to accommodate the newer laptops which do not have a traditional RS232 serial port.
Clive
dummi
Post by dummi » Sun Aug 13, 2006 1:03 pm
excellent, look like i will sell my USB and get an old laptop and serial, thanks chaps
Paulm
Post by Paulm » Sun Aug 13, 2006 1:42 pm
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
dummi
Post by dummi » Sun Aug 13, 2006 1:58 pm
thanks Paul i've Pm'd him
MarkB
Post by MarkB » Sun Aug 13, 2006 8:10 pm
I have a Hex-com interface that has serial and use it on a P2 233 laptop. Works fine for me.
@ dummi if your lead is HEX+CAN on USB i'd be interested in a trade for my serial version if your interested
Let me know
Mark
dummi
Post by dummi » Sun Aug 13, 2006 8:29 pm
i've decided to upgrade my OS on my laptop and see how that works out with this lead thanks though
Nige_RS4
Post by Nige_RS4 » Sun Aug 13, 2006 8:42 pm
The tosh laptop I use is the very small Libretto model, which is great with windows 98!
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
dummi
Post by dummi » Sun Aug 13, 2006 8:45 pm
hmm, if i can pick up one cheap i will give it a go!
MarkB
Post by MarkB » Sun Aug 13, 2006 8:47 pm
dummi wrote:i've decided to upgrade my OS on my laptop and see how that works out with this lead thanks though
No problemo...
Mark
Return to “DTC / VCDS”
