Turbo problem need your help
2.7 V6 30v biturbo - 380 bhp
hataw
Post by hataw » Tue Aug 08, 2006 7:07 pm
I am from the Philippines and have a rs4 here last night i took it out and was going around 290kilometers when i lost all power. That is when i noticed the white smoke from the rear. I am sure i blow the turbo and am looking to fix it there is no noise at all just smoke. I hear there is a way to repair it can any one piont me to where i can do this and how much would this cost can i also just buy the kit or do you need spacial equipment to install the repair kit please guys give me some help I appriciate all the info you guys cna give me
simple1
RE: Turbo problem need your help
Post by simple1 » Tue Aug 08, 2006 7:15 pm
If it is oil seals, then there is a fair chance the bearings and shafts will also have suffered some damage..... white smoke usually indicates water in a cylinder, grey-black is burning oil. With the loss of power it may be turbos........or a blown intake pipe. Needs to be checked by somebody who knows what they are doing. Turbos need to be balanced after a rebuild so yes you could fit the repair kit, but would still need specialist balancing after that.
Mik
Post by Mik » Tue Aug 08, 2006 10:33 pm
White is oil, could also be coolant. Black is usually unburnt fuel. Blue is engine troubles, valves or piston related.
You need specialist equipment to repair and balance KKK turbos. White smoke on boost is most likely a damaged turbo, typical bad oilseal sign.
Mik
2014 Suzuka RS6
