Windscreen wiper failure
RE: I
It's advisable to grease up the linkage as these are known to fail but yet the older A4 shape as none of theses problems and before you ask no they don’t fit, totally different.
- shineydave
RE: I
Mine have just done the slowing down thing too. took about an hour to get the rack out, knock out the spindles (after removing the circlip) regrease and re-fit. lovely, back to a quick flick across the screen on intermittent and some high speed clearing action on the second speed. the drivers side one was fine but the passenger side was pretty much solid.
RE: I
Mine became slow and my dealer had the job done under warranty as they classified it as a parts seizure. If you've got an Audi warranty - try that first.
Paul
Paul
Huge Grin
If you dont "do it now" you never will.
Huge Grin
- 1st Gear
RE: I
mine have been slow since i got the car, i just thought that was the way they were?? How long does the process take and what exactly do i do?
Cheers, Alan
Cheers, Alan
RE: I
The process of a warranty claim or the process of doing the job yourself?How long does the process take and what exactly do i do?
Huge Grin
Huge Grin
- shineydave
takes about an hour or so depending on your mechanical skills, it's not too difficult though, you have to remove the ECU and mounting box so there's about 6 electrical plugs to undo but you can't get them wrong when refitting. remove the wiper arms then the 3 bolts that hold the rack and motor in place. once out there's a circlip on the top of each spindle that needs to come off then knock the spindles out of the rack one at a time, regrease and refit, job done
- 1st Gear
- shineydave
normal grease, copperslip is antiseize for components that need to be dissassembled. it's not so much a lubricant as a corrosion inhibiter
- 1st Gear
RE: I
Yes its been reported in here a couple of times. While we are on the subject the rear washer can become seized to the motor arm. So when you hit the rear washer. The jet sweeps with the wiper arm. Both Brooner and myself have experienced that one within months of each other.
So its worth having a look at that from time to time.
