AIRBAG LIGHT
- LeeMarshall
- 1st Gear
AIRBAG LIGHT
Hi, does anyone know how to get the airbag light off? its been put on vagcom by oliew,on sat and no fault code came up! i have tried unplugging the connectors under the drivers seat but no luck. Anyone else had this problem? Cheers Lee
ronaldmacdonald
no fault code, I think on vag-com you can connect directly to the airbag module. I had the same thing but it turned out to be the passenger side connector - although I managed to get a code which tells you which airbag is faulting. In the absence of any fault code I would try the passenger side and put the vag-com on again. If its actually the air bag control unit gone bang then that could cost a few $$. Cant remember when you are supposed to have the air bags changed, 8 years or 12 years spring to mind.
Lee, you said you tried to do something with the connectors under the seat? i cant remember if these get crusted up or need cleaning, shame my battery died on the laptop im sure we could of sorted it
we should arrange a meet in the midlands, im more than happy to bring my laptop to help sort problems
Ol
Ol
S4 B5 - MRC
- LeeMarshall
- 1st Gear
- mikeyquattro
- Top Gear
tartan_rob
Users browsing this forum: No registered users and 110 guests
