To VAG-Com users, FATS times database for the Euro S4s
I think 3rd is a different ratio on the RS4 box. Your boost looks very high. Your timing is
good in the midrange but poorer in the higher RPM's - probaly due to the amount of boost you
are running. Your cf's are pretty low so I don't think you are retarding too much.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Even so, I can get a FATS time of around 3.2s on my stage1 RS, so you may well have an issue Gordon. Having said that the current climate will not help your times - possibly wait until it a bit cooler?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Deal doneflashyg wrote:I'm gona swap my rs for an s cause they seem quicker then. Any takers?
G
Clive
time rpm maf throttle timing.
18.1 2200 23.89 9.4 36
18.4 2240 32.86 12.5 31.5
18.7 2240 34.47 12.9 32.3
19.01 2280 37.06 13.7 33
19.31 2320 38.94 14.1 33
19.61 2360 39.36 14.5 33
19.91 2400 41.72 14.9 33
20.21 2480 56.28 20.4 32.3
20.51 2520 68.69 29.8 29.3
20.82 2640 83.44 83.5 24.8
21.12 2720 96.64 84.3 21.8
21.42 2840 112.03 87.1 19.5
21.72 3000 130.64 89.8 18
22.02 3120 151.42 92.9 15.8
22.32 3320 179.56 96.1 12.8
22.64 3480 205.72 99.2 11.3
22.93 3720 228.92 100 10.5
23.23 3920 238.06 100 10.5
23.55 4120 253.89 100 11.3
23.85 4320 260.14 100 9
24.16 4520 269.61 100 12.8
24.49 4720 276.5 100 12.8
24.82 4960 289.42 100 12.8
25.16 5120 286.86 100 12.8
25.5 5360 282.47 100 12
25.85 5560 295.25 100 12.8
26.21 5760 311.19 100 10.5
26.57 5920 315.25 100 10.5
26.94 6160 333.81 100 14.3
27.32 6360 328.94 100 13.5
27.7 6560 334.78 100 18
28.07 6680 343.67 100 18
28.45 6880 347.69 100 14.3
28.83 7040 352.78 100 14.3
more fats logs.
I am very concerned. It may be my petrol so I will use a different supplier.
But I am puzzled.
Basically I am at WOT from 2k rpm but the logs show 100% at 3700.
Why is this is it bad fuel or is mt TB Broken.
I re set it but it barley changed anything.
My fats are not good. My maf readings are not what they should be.
Maf and dvs are brand new boost if fine.
logged the cfs here are the results
1234.
0 3 0 0
0 3 0 0
0 3 0 0
0 3 0 0
0 3 0 0
0 3 0 0
0 0 0 0
0 0 0 0
0 0.8 0 0
0 3.8 0 3
0 3.8 0 3
0 3.8 0 3
0 3.8 0 3
0 3.8 0 3
0 0 0 0
then 5 and 6
0 3
0 3
0 3
0 3
0 3
0 3
0 3
0 2.3
0 4.5
0 4.5
0 4.5
0 4.5
0 4.5
0 4.5
3 4.5
3 3.8
3 3.8
3 3.8
3 3.8
3 3.8
3 3.8
2.3 3
2.3 3
2.3 3
1.5 2.3
1.5 2.3
1.5 2.3
0.8 1.5
0 0
0 0
1.5 1.5
1.5 1.5
0 0
0 0
car is running -7 and -6 on lambdas but no boost leaks.
logged the egts not over 945 consistently.
absolutely no engine fault codes.
Car did pull 191% load and 364 maf from 6000 on words when running right.
Cannot understand reasons behind the drop , and poor fats,
Can any one help.
Thanks .
G
more fats logs.
But I am puzzled.
1234.
0 3 0 0
0 3 0 0
0 3 0 0
0 3 0 0
0 3 0 0
0 3 0 0
0 0 0 0
0 0 0 0
0 0.8 0 0
0 3.8 0 3
0 3.8 0 3
0 3.8 0 3
0 3.8 0 3
0 3.8 0 3
0 0 0 0
then 5 and 6
0 3
0 3
0 3
0 3
0 3
0 3
0 3
0 2.3
0 4.5
0 4.5
0 4.5
0 4.5
0 4.5
0 4.5
3 4.5
3 3.8
3 3.8
3 3.8
3 3.8
3 3.8
3 3.8
2.3 3
2.3 3
2.3 3
1.5 2.3
1.5 2.3
1.5 2.3
0.8 1.5
0 0
0 0
1.5 1.5
1.5 1.5
0 0
0 0
Can any one help.
Thanks .
G
Finally got myself VAG-com and managed a couple of logs...
Time Revs MAF Throttle Timing
20.82 2680 76.22 32.5 24.8
21.12 2720 91.94 100 18
21.42 2880 115.22 100 17.3
21.72 3000 143.11 100 12.8
22.03 3160 165.97 100 12
22.33 3360 177.44 100 11.3
22.63 3520 193.31 100 9.8
22.93 3720 200.33 100 9.8
23.23 3880 203.03 100 11.3
23.53 4080 213.17 100 11.3
23.84 4240 224.47 100 9
24.16 4440 216.25 100 12
24.48 4600 214.56 100 13.5
24.81 4760 223.78 100 12.8
25.14 4960 230.86 100 13.5
25.47 5120 231.86 100 13.5
25.82 5280 235.67 100 15
26.16 5440 245.53 100 14.3
26.51 5560 254.69 100 15
26.87 5760 254.69 100 12.8
27.23 5880 256.08 100 16.5
27.6 6040 251.31 100 18.8
27.97 6160 246.56 100 20.3
28.34 6280 244.53 100 21
28.72 6400 240.53 100 21.8
29.1 6560 237.22 100 24
29.48 6640 233.97 100 24
29.85 6760 235.28 100 26.3
30.23 6880 239.83 100 24
Fats time of 5.27s on a totally stock car other than the custom MRC map. Outside temp was about 23C, half a tank of optimax and a few bits n bobs in the boot. Does this seem ok?
Cheers,
Jez
Cheers,
Jez
Jez - seems very good to me - if you take a look at the MRC FATs database, you'll see that it beats my best run (done at 18C) and I've got RS4 exhaust with gutted precats.
Clive
Users browsing this forum: No registered users and 44 guests
