Convert from Navi-Plus to Navi DVD RNS-E with tuner
abc5k
Post by abc5k » Mon Jul 10, 2006 2:47 pm
Hi can anyone help me or point at right direction .
I have audi S6 year 2000 it has OEM navi Plus and OEM TV tuner , i would like to change it to RNS-E DVD Navi ,RNS-E fits perfectly into my car but non of the cables fit , is there an adapter and would i have to change my tv tuner to?.
please help me as i already got DVD RNS-E but cant use :cry:
peterb
RE: Convert from Navi-Plus to Navi DVD RNS-E with tuner
Post by peterb » Tue Jul 11, 2006 10:33 am
I bought my adapter cables from Kufatec. You'll need the main power/speaker cable adaptor, the gps antenna adaptor and the radio antenna adaptor.
With regard to the TV tuner, are you aware that your original tuner will not work with the RNS-E? You'll need to source a 'C' suffix unit, which will probably come with the full 5 metre long cable.
Whereabouts are you? If you're anywhere within reach of Reading, I could give you a hand.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
abc5k
Re: RE: Convert from Navi-Plus to Navi DVD RNS-E with tuner
Post by abc5k » Tue Jul 11, 2006 11:37 am
peterb wrote:I bought my adapter cables from Kufatec. You'll need the main power/speaker cable adaptor, the gps antenna adaptor and the radio antenna adaptor.
Cheers mate I think you have answered most of my questions,
I will try it out but first I will have to replace my RNS-E screen it got damaged on delivery and now I will have to sort out a new screen any suggestions?
I have parking sensor on front and rear of my car , rear works fine but fronts are not connected , its had a bumper change and it may have come with the parking sensors I assume? . Would I be able to connect it with rear set?
Thanks for the offer of helping out, I really appreciate it! Reading is a bit far for me , I live in east London. Thanks Peter :D
peterb
Post by peterb » Wed Jul 12, 2006 1:52 pm
abc5k wrote:I will try it out but first I will have to replace my RNS-E screen it got damaged on delivery and now I will have to sort out a new screen any suggestions?
Sorry, no idea on this!
It appears that the control units have a different part number for the 4 and 8 channel parking sensors. If the car originally came with park assist front and rear, then it might just be a matter of connecting up, or even a VAG-COM setting. Otherwise it might involve having to change the control unit.
Suzuki Carry 660
abc5k
Post by abc5k » Wed Jul 12, 2006 2:54 pm
Thanks Peter ,
this car had rear only from factory .....
craigyb
RE: Re: RE: Convert from Navi-Plus to Navi DVD RNS-E with tu
Post by craigyb » Wed Jul 12, 2006 4:49 pm
I agree with what Peter has said, but only if your car has an RNS-D fitted and not the C and is equipped with can bus for the cluster and radio. Check your existing nav system for can H & L connections, just with it being a 2000 model it is just borderline.
Return to “Electrical”
