k04/rs6 hybrids airflow character
dummi
Post by dummi » Sat Jul 08, 2006 5:26 pm
Mihnea has already convinced me these are the way forward with their high flow i'm just looking for specifics on airflow
i'm going to use rs4 heads, hopefully tubular manifolds, but probably standard 2001.5 IM, budget is killing the mods ! so what kind of flow can they give 3000-8000rpm+ when do they run out of puff...
thanks
dazzer
Re: k04/rs6 hybrids airflow character
Post by dazzer » Sat Jul 08, 2006 6:58 pm
dummi wrote: when do they run out of puff...
thanks
Long after your licence......
Paulm
Post by Paulm » Sat Jul 08, 2006 8:24 pm
dummi wrote:so what kind of flow can they give 3000-8000rpm+ when do they run out of puff...
thanks
Need to get a compressor map to work that out
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
dummi
RE: Re: k04/rs6 hybrids airflow character
Post by dummi » Sat Jul 08, 2006 9:06 pm
and here they are.. just need to learn how they work now so i can read them
http://forums.audiworld.com/s4/msgs/1835636.phtml
dummi
Post by dummi » Sat Jul 08, 2006 9:43 pm
after much studying (not really)... at 70% volumetric efficiency the compressor map is further to the right .175 for rs6k04, .158 for rs4k04 ... how the volume exactly converts into rpm in numbers i don't know.. i don't really know what i said there making this is a topic that needs further research
Paulm
Post by Paulm » Sun Jul 09, 2006 8:27 pm
That turbo can make 1.4 bar all the way to 7k and still stay @ around 73% efficiency.
1.4 bar is all it is good for really but it can flow loads of air.
It flows more than the K16 bottom end but slightly less the the straight RS4
Sorry not got the time to work out revs etc as I am at work I will though when I get home unless someone else does it.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
dummi
Post by dummi » Mon Jul 10, 2006 2:52 am
thanks Paul thats plenty to be going on with
Paulm
Post by Paulm » Mon Jul 10, 2006 10:24 pm
Ok here you go.
this is just on paper remember turbos can act differently in real life but it gives you a pretty good representation of what it will do
Dots 1 to 12
1= 1bar @ 2800rpm
2= 1.1bar @ 3000rpm
3= 1.2bar @ 3200rpm
4= 1.4bar @ 3500rpm
5= 1.4bar @ 4000rpm
6= 1.4bar @ 4500rpm
7= 1.4bar @ 5000rpm
8= 1.4bar @ 5500rpm
9= 1.4bar @ 6000rpm
10=1.4bar@ 6500rpm
11=1.4bar@ 7000rpm
12=1.4bar@ 7500rpm
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
DavidT
Post by DavidT » Mon Jul 10, 2006 10:52 pm
What top end mods will you do to allow you to rev to 8k ?
dummi
Post by dummi » Tue Jul 11, 2006 3:00 am
top end? do you mean bottom end? lightened crank , uprated rods. should be able to get more than 8k out of it... HTH?
tartan_rob
Post by tartan_rob » Tue Jul 11, 2006 8:44 am
Those spool up figures look about spot on and in-line with what I'm getting but they can provide loads more boost than that, Mihnea was going to have mine peaking at 1.7 I think with 1.5 at redline. I am still running std cats but they should spool up quicker once they have been changed for 100cell jobs...
2017 Kawasaki Z1000
2014 RS6
2014 S1
JonnyX
Post by JonnyX » Tue Jul 11, 2006 9:39 am
dummi wrote:top end? do you mean bottom end? lightened crank , uprated rods. should be able to get more than 8k out of it... HTH?
I think you will need to do something with the valvetrain as
well to get to 8K+
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
dummi
Post by dummi » Tue Jul 11, 2006 10:19 am
@paul thanks theres plenty there then
@jonnyx yeah i've been looking at mechanical lifters, its just out of my budget right now, more likely next year. topend is heads rs4 with rs4 cams, revolver do some street cams and more aggressive race cams i'll be looking at..
Paulm
Post by Paulm » Tue Jul 11, 2006 11:19 am
Yeah I am sure you could run more than 1.4bar but I just plotted a graph relevant to the compressor map you see.
1.4bar @8k would be a flying machine
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
tartan_rob
Post by tartan_rob » Tue Jul 11, 2006 12:47 pm
FYI...I think you'll find the NA heads from the 2.8 flow approx 30% more air.....
2017 Kawasaki Z1000
2014 RS6
2014 S1
Users browsing this forum: No registered users and 71 guests
