100,000 Mile Service
- BlackShadow
What does the 100,000 Miles, 10th Fixed Service for and Audi S4 entail? I was thinking about taking it to my independent VW specialist - Kwikas Motor Engineers, Trinidad St, E14 (2 miles form my place) - as apposed to taking it to QST in Haywards Heath (who did the mods) which is more like 100 miles away going around the M25. If it is simple I'll go to the local guy, if not then QST I guess. Your opinions?
Silver S4 Saloon
MTM Stage 4 (385 bhp), Mov'it Front Brakes, RS4 Rear Brakes, H&R Coilovers, Tanoga Shortshifter.
- SimonS4MTM
- Top Gear
RE: 100,000 Mile Service
It is only the same as the 20k service.
If not already done, I would also change g'box and diff oils and the fuel filter, along with spark plugs. All in addition to 20k items.
The service book is of course very sparse - maybe someone has a link to exactly what should be carried out at each service?
Clive
- BlackShadow
Yes, such a link would be good. You could have a sensible discussion with the mechanic then knowing what he is suppose to do, and what extra is recommended to ensure our beatiful little S4s are kept in top condition.
Silver S4 Saloon
- SimonS4MTM
- Top Gear
Re: RE: 100,000 Mile Service
It is sparse because they dont do muchCliveH wrote:The service book is of course very sparse - maybe someone has a link to exactly what should be carried out at each service?
Absolutely. Can anyone help...?BlackShadow wrote:Yes, such a link would be good. You could have a sensible discussion with the mechanic then knowing what he is suppose to do, and what extra is recommended to ensure our beatiful little S4s are kept in top condition.
Clive
- SimonS4MTM
- Top Gear
RE: Re: RE: 100,000 Mile Service
I have a check list from my last service, I will dig it out later.
All it says is what it states in the service record.
- SimonS4MTM
- Top Gear
Re: RE: Re: RE: 100,000 Mile Service
So here is the list for 20k
SimonS4MTM wrote: Electrics
Front lights
Rear lights
Interior lighting
Fault memory read
Service display reset
Vehicle exterior
Door arrester, lock cylinder and bonnet catch – grease
Windscreen wash wipe and headlight wash
Windscreen wiper park position
Windscreen wiper blades
Tyres
Vehicle from below
Engine, gearbox, final drive, steering visual check
Engine oil, drain and renew filter
Brake pads
Brake system visual
Track rod ends, check play and security
Swivel joints, check boots for leaks or damage
Exhaust system, check for leaks and security
Under body, check for damage or loose parts
Engine compartment.
Visual check for leaks or damage
Replenish engine oil
Windscreen washer level
Battery level
Anti-freeze concentration
Hydraulics, level and leaks
Air filter, renew
Dust/pollen filter, renew
Final checks
Tyre pressures
Road test
- BlackShadow
RE: Re: RE: Re: RE: 100,000 Mile Service
Thanks Simon.
Silver S4 Saloon
simon u forgot kick the tyres..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
It's only the same as the 20K if the full 80K was done properly...
2001 Silver S4 Avant
- SimonS4MTM
- Top Gear
