different tread same axle?
bobjebb
Post by bobjebb » Wed Jun 14, 2006 2:53 pm
Just wondered as a girlfriend came to visit at the weekend and I noticed. Is this ok?? They are the both michelin pilots. Thanks
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
harry
RE: different tread same axle?
Post by harry » Wed Jun 14, 2006 3:00 pm
I wonder if she goes out on the town with different shoes on too? :roll: or perhaps this is a subtle indication that her collar 'n' cuffs don't match :lol:
AFAIK its best to have matching tyres and tread depth on drive axle to promote stability and maintain tyre/traction behaviour. especially so with our Quattros but perhaps just as relevant on a beemer with all the power going thru the back wheels.
Practise safe sex & drive a hybrid if you can...
simple1
Post by simple1 » Wed Jun 14, 2006 3:24 pm
I had this problem when a brand new pilot 1 got a nail in it, new Pilots are symetric, and was advised to replace both by local tyre company.... very expensive puncture... BMW backed up the advice :(
bobjebb
Post by bobjebb » Wed Jun 14, 2006 3:54 pm
Harry, no worries. Her collar and cuffs do match. She has blond hair and a blond fanny. I know, I have seen them.
Anyway, it was just that they said to her it was fine at the garage, and I was a little sceptical, thats all, but as long as it's not dangerous, cos this bird needs all the help she can get when she's behind the wheel of a car.
Back with C6 RS6
And again C7 RS6
s4woody
Re: RE: different tread same axle?
Post by s4woody » Wed Jun 14, 2006 7:12 pm
She has blond hair and a blond fanny. i take it by fanny u mean hair and not skin... :shock:
GARTH ROAD MOT CENTRE LTD
020 83353032
harperboy
RE: Re: RE: different tread same axle?
Post by harperboy » Wed Jun 14, 2006 7:38 pm
s4woody wrote:She has blond hair and a blond fanny. i take it by fanny u mean hair and not skin... :shock:
Now that is off topic!
Yellow Mini One, AmD tuned to 130bhp, K&N induction kit, Milltek cat-bac exhaust, go-faster bonnet stripes (at least another 10bhp!)
simple1
Post by simple1 » Wed Jun 14, 2006 7:45 pm
:sekret: But about the most interesting thing that has been posted all day :smile_smoking: Ho hum :bigblink:
shineydave
Post by shineydave » Thu Jun 15, 2006 10:37 pm
presumably you don't mean they match the tyres. one bald, lol
Dippy
Post by Dippy » Fri Jun 16, 2006 1:24 pm
I both agree and disagree with Harry.
I agree that for a RWD BMW, the significantly different tread pattern is bad news, particularly in the wet.
I disgree that the situation is worse for Quattro. Since it is 4WD, the difference in tread pattern has less impact. This is true for tread depth too. If anyone wants to come back with that old chestnut about "transmission wind-up", please bring the evidence this time :)
2001 Silver S4 Avant
harry
Post by harry » Fri Jun 16, 2006 1:31 pm
Dippy I wasn't indicating it was worse for quattro but just perhaps it adds more unecessary stress on the centre diff (from reading earlier threads on here)
Is this what you are refering to by "transmission wind up"? If so then I have no evidence of this per se, only what I've read on here :roll: and I change her boots in fours regarless
I'd be keen for some clarity too TBH
bobjebb
Re: RE: Re: RE: different tread same axle?
Post by bobjebb » Fri Jun 16, 2006 5:01 pm
Dippy wrote:I agree that for a RWD BMW, the significantly different tread pattern is bad news, particularly in the wet.
so should they be better on the front?
ta
Back with C6 RS6
And again C7 RS6
SimonS4MTM
RE: Re: RE: Re: RE: different tread same axle?
Post by SimonS4MTM » Fri Jun 16, 2006 5:06 pm
Depends how well she wants to brake in the wet!
TarmacTerrorist
Post by TarmacTerrorist » Fri Jun 16, 2006 6:56 pm
Dippy wrote:I disgree that the situation is worse for Quattro. Since it is 4WD, the difference in tread pattern has less impact. This is true for tread depth too. If anyone wants to come back with that old chestnut about "transmission wind-up", please bring the evidence this time :)
1. For a modern rwd car with a bit of power under the hood, I would run the same tryes all round epsecially on the rears (rain, dry, whenever). The missus has a fwd 1.0 ltr Yaris that when she tw*ts it up the kerb I replace one trye at a time with whatever they have on the shelf.
2. Old chestnut?? wtf??, I can assure you that the car did not like running different tyres front to rear on the rs4. I could feel (and hear) very bad transmission wind-up coming through the car from the centre diff, simple as that. Are you questioning my abilty to read what it happing to the car through the feel in my arse when I change something around on it??? This problem was appartent the momment I swapped them around on the car thankyou very much!!
I've been thinking about what could actaully be causing this problem and I would suggest the trye tread pattern has ALOT to do with it !! probably in the way that the 2 different cut patterns will shift and react under high loads on the road surface. I found the car felt worse (as gumball posted) when accererating in a straight line, no corners involved what so ever.
Other things it could possibly be are differing r/dia, but that doesnt stand when changing just 2 tyres of the same make, you just dont get the problems like 2 different tyres has.
Trye wall stiffness?? Possible....Centripital forces will have an effect on the shape of the tyre, the stiffer the wall the more it will be able to hold its shape i would have thought.
Differing compounds and hardness of rubber?? Again very possible.
However, I still favour the block shift thoery and would suggest that its effect are worse when both sets have plenty of rubber left on them :tongue:
Last edited by TarmacTerrorist on Fri Jun 16, 2006 7:07 pm, edited 2 times in total.
Too much is bad.
Plenty is better.
TarmacTerrorist
Post by TarmacTerrorist » Fri Jun 16, 2006 6:58 pm
Yes, blonde fanny. Very nice.
Too much is bad.
Plenty is better.
Return to “General Car Chat”
Users browsing this forum: No registered users and 112 guests
